Well, i guess we can be whatever we like on the internet. I can can feel the difference taking the stickers off my fork. That's how skilled i am.5mm is huge to me. If you don't have the skills to feel that difference...well, that's on you.
Yeah, I guess I could just tell 10mm. When playing with stems I can definitely tell practical differences between stems 15mm apart. 5mm, no way (I have a 45 and a 50 that I have swapped). I guess 10mm is around the smallest that I could see making a difference.Given that typical frame sizing is in 20 mm increments or around that, I would guess 10mm is about as fine grained as most people would care. On the same bike, I would distinguish 10mm. 5mm - unlikely.
A small rotation of the bars can change reach by several mms either way, so there's another way to fine tune.5mm is huge to me. If you don't have the skills to feel that difference...well, that's on you.
Also, there is a misconception stated here in a few places that any desired higher grip position / bar height can simply be achieved by adding stem spacers. Thus some earlier in the thread argue there is no point to riser bars (why not just get flat bars and put in spacers?)Hi/low rise handlebars are just one tool to help you get the optimal bar height/reach for a particular frame/fork/wheel/body geometry combination. The same person may have one bike that requires a high rise bar and another that requires a low rise bar.
I think it goes without saying that The recommend option to add more spacers comes with the condition that there is enough steer tube to do so.Old thread, but +1.
This is only true to an extent because at some point you run out of steerer tube. The top of your stem should technically sit 3-5 mm above your steerer tube to allow for enough stem purchase to be safe while giving enough room for the top cap to preload the headset bearings property. Thus your bar height adjustment is capped by the length of your steerer tube, and some bikes (older geo trail bikes) may then be left with bar rise as the final adjustable variable to get a higher grip position (assuming you don't want to run a long, angle CC stem). Older trail geo seems to favor a forward cross country style position where the grips are well below the seat at average for a given frame size. You may need spacers AND bar rise just to get the bars up to seat height if running a modern short 0 degree stem.
it doesn't appear that is common knowledge reading the thread. Thus wanted to add to the record to clarify for future readers. Leaving the correct amount of stem above the steerer tube is crucial.I think it goes without saying that The recommend option to add more spacers comes with the condition that there is enough steer tube to do so.
Keep in mind that a lot of people have spacers above their stems as well, thus allowing for more adjustment this way.it doesn't appear that is common knowledge reading the thread. Thus wanted to add to the record to clarify for future readers. Leaving the correct amount of stem above the steerer tube is crucial.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Yes that is of course true, the point again is there is an upper limit that is a cap on how high you can go.Keep in mind that a lot of people have spacers above their stems as well, thus allowing for more adjustment this way.
And when the bike is new, you can make the steerer however long you want before you get the fit dialed in.
I love the boots. I made a boot out of an old inner tube. All I've read on the webz is that muddy grit will destroy a dropper post, so I keep that sh!t off mine.The bar looks fine, but pls take off the boot of your GD, it will look alot better. I run my GD without the boot for 2yrs now, with no problem.
