1 - 20 of 103 Posts
Discussion Starter #1
Why is it that most people seem to run low rise bars? I don't see anyone running 2in rise bars, is there a reason for that?
They're really really tall..
More guys are moving towards more travel, with a 160mm fork you're already up pretty high, a flatter bar keeps you in a more neutral position. Even 140's get you pretty upright. Having a big fork and huge tall bar means you really gotta fight the bike to keep the front end down on climbs.
Biking Like Crazy!
When I used to run a high rise bar I would have to really
tighten down the bar clamps to keep them from rotating
on "heavy" hits. Now that I run mostly low rise carbon bars
I can't/don't need to tighten them so much.
I also agree with the other posters reasonings.
Law abiding citizen
all those reasons above plus they look sort of lame. :D
  • Like
Reactions: d-bug
Rider, Builder, Dreamer
All of these are true, but consider the fact that even a lot of DH racers run flat bars; you know that they're not climbing.
Biggest thing though is that it gets you in a more aggressive stance with a lower center of gravity. Lower center of gravity = more stability whether you're climbing or descending.
I run Sunline V1s 745mm wide with a 38mm rise (1.5 inches) and it feels just right on my bike right now. My bike's only got 120mm travel though.
SamIAm
i want more 50mm 29+ bar choices. only ones right now are deity and answer.
i AM a tall rider. and most all of it is in my legs so seat has to be higher. would like bars up a bit so i dont have to crank my neck so much.
no taller than 60mm. 40-50mm juuuust right for alot of us.
All boils down to individual preference and riding style....
Gone thru a whole slew of bar isn the past few years. Was comfy with a 710 mid rise for a long time but then gone on to try just about eberything out there as some of my ridies got bigger descents and i find the leverage lacking....
Changes including long flat 760, all the lo-rise in various lengths... Now Im back on a mid 30mm rise... but length has gone up as well to 750mm. Best compromise for everything up, down and in the air....
The inportant thing is keeping bar height the same when changing bars.. that way one less variable to deal with.. It gets tough as travel gets longer and the one way is to start off with a frame that has as short a headtube as possible and u have some spacers underneath the stem. Im lucky in that sense that my frame allows that kind of options as I progress and try out diff length and rise of bars + stem combos.
Having said--even if bar height and all are kept constant-- climbing is just not as nice as the rise increases... but what works against the climbing is compensated with stability during air time for me.. flat and lo rise just seem to twitch a lot more when pop off something on the trail..
RIP Friendgirl
FUNN Fatboy 750mm length 50mm rise
I've done the low rise thing & really didn't work for me. Kinda think it's more a fashion thing. Run whatever feels good.
I was interested in this thread for the reason you stated here. While I am not tall, I think my legs are for my height. I have very wide shoulders and my arms are short for my height. I recently changed sizes in bikes to fit me better, but in the process it dropped my stack height and in turn dropped my bars away from my short arms. Now when I ride, my lower back is killing me and I really have to torque my neck to look down the trail. I bought some 40mm rise bars. I know climbing will suffer, but climbing already suffers when my lower back is in pain. Right now I'm worried that my new bike might not fit me.... but everything on it fits perfectly except for the fact I'm bending over to 'reach down' to my bars. Do you think riser bars would help this situation?
taller bar can address a physical issue like flexibility, stregnth or injury too. for me finding the sweet spot for tire grip and a little air time loft control is key as i get older. I pay attention to where my grips' height are and keep that constant on a set-up regardless of bar height.
i run 38mm renthals right now slammed on 160s. It works well but my ride style is very bmx oriented with more standing and attacking things so i don't have any issues with the front end and climbing(boring!!haha!) i could care less about that. depends on the bike too for wheelies or when you're trying to manual and how responsive the rear set up is for doing those things.
Purveyor of Trail Tales!
Hi Mr. kneetowaist,
I absolutely love my 50mm / 2 inch rise, 30.5" wide bars! Some folks speak of climbing issues when using a high rise bar. But I deal with that by using the TALAS feature on my fork to drop the front end on climbs.
My riding style is all about finding something to jump onto, jump off of or jump over. Therefore I really appreciate the ability of the high rise bar to help me loft the front end of the bike with little effort!:D
As far as I'm concerned anyone who knocks the high rise bars based on looks has a case of misplaced priorities!;)
Here is a shot of my 2007 Specialized Enduro Pro after I tweaked it to perfection for me!
Take care,
Michael:thumbsup:
  • Like
Reactions: BigBill
I wonder how many people are running low rise bars with 20+ mm of spacers under their stem. I see it a lot. Does it defeat the purpose?
Biking Like Crazy!
Look at the previous picture in the above post. Looks like 25+mm spacers with a high rise bar. I guess what ever it takes for good fit/feel for the rider.
My resaon for not using them (see post #4) is I don't trust them not to rotate on one of my "smooth" landings.
And people that cut their steerer tubes to short...arghh!:p
SamIAm
so...
deity, answer, funn, spank.
and on the climbing issue. its not that hard to pull ur chest closer to the bars a bit on the steeper bits to keep the front end down.
50mm Answer AM's feel great! I had some low rise Easton Monkey Bars before, I was dubious about putting high rise on there but ended up being a great improvement, loads more confidence in the air and in the steeps. I like a playful bike:D
FWIW I run 140mm forks, 50mm stem slammed to the headset.
1 - 20 of 103 Posts
