1 - 6 of 6 Posts
Hairy man
Discussion Starter · #3 ·
Zanetti said:
Would you rather it feel rusty? ;)
They always come coated in light grease to prevent corrosion.
Oh I'm happy it's not rusty. I'm just wondering if I should strip it before lubing it. Or can I just throw some tri-flo on top of the grease?
The devil is an angel too
I am almost certain that SRAM advices against degreasing the chain. They pack them with that special "lube" -aka: greassy waxy thing that picks up a lot of dirt- and it is supposed to be the cat's meow.
If the search engine is up and running, you may want to look for threads on that issue -I know that it has been discussed at least a couple of times here.
All 26.5" all the time!
Using a bit of tri-flo shouldn't be a problem, just wipe the chain down real good before riding. Any excess grease/lube on the outside of the chain won't help things.
Dwight Moody said:
I just bought a new chain (a SRAM P-58, I think. It's an 8-speed chain from SRAM) I took it out of the box and it felt waxy. What's up with that?
yeah, sram uses some stuff called Gleitmo? There's been some good talk here about it in the past.
Bottom Line- it's a great lube! Don't degrease it, but once it wears off, apply your lube of choice.
1 - 6 of 6 Posts
