It gets said often that you want air on the front, but coil on the back.
I've just been asked why, and to be fair it does not make sense to me.
I was wondering if anyone had any insights?
My thoughts:
Forks are larger, more seal contact area, and more flexible. They functionally have a leverage ratio of 1:1. All of these point to friction having a greater effect on the front.
Unless you are running a proper fork (triple crown) then the air spring is likely 2 chamber and will have a weird rate. This matters less on a shock as you can correct the rate with varying frame leverage.
Forks are generally seal facing up, so need tighter sealing to prevent mud ingress, sealing doesn't need to be as tight on a can (though higher air pressure).
Personally I can feel the difference between a dorado coil and a dorado air (with probably the best air spring on the market).
I can also tell the difference between a cane creek coil and air.
So is the opening statement correct?
Is it engineering or sales and marketing?
My thoughts:
