Sad, the owners will be missing out on such pleasant sounds.+1 for Chain Slap
4th answer: Makes for a more rigid frame in terms of torsion.Here is a better picture showing how it is bent downward:
Ring, Ring! Hello?Sad, the owners will be missing out on such pleasant sounds.
I'm here, how can I help you?Ring, Ring! Hello?
Marin Pine mountain is an example of this.It's so they can have a short chainstay on a bike with big fat tires. You might notice that if it were higher, there is very little room between the chainring and tire.
Other strategies are (for metal bikes) having that junction machined as one piece so it can be thinner, then welding it to a tube after it clears the chain ring.
Why would it do that? If that were the goal wouldn't they do it to NDS too?4th answer: Makes for a more rigid frame in terms of torsion.
But Salsa is not the originator of the elevated chainstay design. I remember seeing those on Nishiki's back in the 90'sthis allows room for a big tire, a chainring, and short chainstays. Salsa solved the problem thusly
Trek Stache
Specialized
nobody said salsa was the originator. Yeti was doing them in the 80s too, as was brave. Kinda lame solution, imo.But Salsa is not the originator of the elevated chainstay design. I remember seeing those on Nishiki's back in the 90's
https://forums.mtbr.com/vintage-retro-classic/elevated-chainstay-bike-history-questions-590280.html
Thanks. I'm aware of that.nobody said salsa was the originator...
