I had a Turner XCE, road 10,000 miles on that bike and never rebuilt the suspension. Never had a single squeak or issue. Turner used bushings instead of ball bearings for all the reasons you mentioned.
I've used olite self lubricating bushings on DMR vault pedals with chromoly steel axles. I found igus plastic bushings longer lasting. Part of the reason is vault seals suck. More robust sealing would extend life for sure, but I'm still not convinced life span would be as long as bearings. I've never replaced the outboard bearing on vaults but I've gone through countless inboard bushings. I suspect you're right in saying bearings allow for sloppier tolerances which is appealing to manufacturers. The bike industry is notorious for sloppy tolerances. PFBB's creak because of sloppy tolerances. DM rings can creak because of tolerances. Facts are we really don't need exacting tolerances for bikes other than certain places and bearings would be a good way to avoid having to tighten things up. We need to bring back threaded BB's as a standard because the industry has proven an unwillingness to tighten BB shell/bb cup tolerances.Most of the problems mentioned above existed because builders used the wrong types of bushings, shafts, or designed the suspension poorly. Oilite makes sintered and bronze bushings which do not require lubrication. Use these with either chromed steel or hard anodized aluminum pivot shafts (preferably tubular chromed steel), good design, and a simple dust seal and all of the aforementioned problems go away. I mean, I have no horse in this race, but just looking at it from an engineering perspective. For all I know it could be that bearings are used to reduce the engineering and finishing effort required.
If you use a bushing the internet will tell you are wrong and the bike is crap...no matter how well you designed it or how well it actually works. Some fights are just not worth it.Am I missing something?
They are not cheaper because they require higher precision from the frame in terms of alignment and machining, to do them right with grease ports requires additional considerations. Way easier just to slap a couple skateboard bearings in like most companies do.Just a random thought of the morning. I can think of whole list of reasons to use bushings instead of ball bearings. In motors they often use Oilite bushings on the armature shaft. I know some makers such as Transition (I think) use a bushing or two. They can't get internally contaminated, they can't get knackered as easily during press/pull, they can't do that weird thing bearings do under rapid succession micro rotations in both directions (forget what it is called), they don't need additional maintenance or lubrication, they are cheaper...really I can't think of single reason to use ball bearings instead, yet everyone does. Am I missing something?
No.I would assume bearings handle lateral shock loading forces better. Is that even a thing?
That is the kind of thing I was assuming would happen. I guess you can tighten the design engineering to avoid that.I owned a FS bushing bike once....ONCE. It was a Psycle Werks Wildhare. I liked how the bike rode, but the bushing experience made me swear-off bushing bikes. The Wildhare was set up in a way that the movement of the rear end always rubbed the bushings. Eventually, the bushings ate away at the aluminum frame, which resulted in (what I called) perma-play. It was a headache. Perhaps other bushing designs avoid my problem, but the experience put a bad taste in my mouth.
Could and average person have replaced one or the other of them more readily by themselves?My son had a Giant Reign 26er with bushings. The bushings had to be replaced.
I have a Giant Trance 29 with bearings. The bearings had to be replaced.
The bushings cost $16 to replace. Parts and labor.Could and average person have replaced one or the other of them more readily by themselves?
When we were younger bike engineering was much less developed - but as a 14 year kid with an avergae set of garage tools I could rebuild replace or repair every moving or distinct part on my bikes. Today it's much more likely that I have to buy a whole new component AND pay to have it installed.
The tools cost more than the parts they service etc etc..
