forceyoda said:
The TALAS has a larger air chamber than the Float, that is why it has a more linear feel to it and why there is a difference in PSI for the 25% sag. The 80 psi is off the recomended for the TALAS probably because you have it in the 4 inch travel mode when the recomendations are for the 5 inch.
Interesting... I didn't realize you have to pump more into TALAS air chamber in order to maintain the same sag when travel is reduced. Correct me if I am wrong but doesn't FOX mention on their ad that TALAS fork auto adjust for air spring rate when travel changed so that you don't have to pump the air in or out to maintain sag? I will try to pump 60 to 65psi (160lbs weight) at 5" travel to see if I get a correct sag of 20 to 25%. Right now, if I was to pump 60-65psi at 4" travel mode, zip tie on fork stanchion sags about 1.5"...way too low and steepens the head angle way too much on my bike. Fox Float 100mm RLC fork on the same bike compress about 0.8-1.0" at that same pressure.
I suppose I can ignore Fox's recommended pressure and pump 80psi at 4" travel mode but the it feels too stiff and I feel a lot of compression spike on the trail. What I usaully end up doing is, run about 70-75 psi and run at about 4.3 inch travel. A bit of compromise but this way fork doesn't feel too stiff and frame's 4" based geometry doesn't change too much...albeit at 30 to 35% sag.
STH
