Read everything under Derailleur and Shifting (front and rear)cohenfive said:
http://www.parktool.com/repair_help/FAQindex.shtml#drivetrain
Read everything under Derailleur and Shifting (front and rear)cohenfive said:sorry for the venting but i continue to have trouble getting my shifting adjusted well. i've looked on the site here as well as the information from shimano on derailleur adjustment but i don't seem to get it--the shifting on the bike is very sloppy--the chain will skip gears on occaison and i have a hard time getting into full granny. the bike is very new so it's not a hardware issue..
this is my second mtn. bike and i haven't had much success with the first either. i end up bringing my bikes to my lbs for adjustment--that's ok but i should be able to get this down myself.
anyone have suggestions on a systematic procedure to get their derailleurs working smoothly--my haphazard method (messing it up until i cry uncle and go to the lbs) isn't working for me..
thanks!
i've looked at the park tools stuff but hadn't seen sheldon brown's info. this looks promising, i'll be taking a look later today. i have standard shimano components so hopefully everything applies.006_007 said:As stated earlier the parktool website is a great place to look. Also take a look at Sheldon Browns site, he has some amazing articles on cycling:
www.sheldonbrown.com/derailer-adjustment.html
given my lousy history on getting them dialed in i've already made an appointment at my lbs for later in the week. in the meantime i'm going to keep working on them to see if i can get them dialed in myself. the bike is basically new and i've visually looked at the hanger (i've had one of those blow out on me before) so think it's adjustment rather than a hardware issue.Rufudufus said:...I found Park's advice on adjusting the front derailler extremely helpful.
But you shouldn't need to adjust deraillers very often, once they're dialed in. You might have bent derailler hanger if your cassette is giving you grief. Your LBS should have a tool to check it and re-align it. You should have them check your chain, too, and see if it's stretched beyond the limit.
