@ nino:
Well, I
race with eclipse and use real tubeless for hard training rides. So much for that.
A
little more rolling resistance is better than
a lot more weight, I think.
Of course you can't compare a Vertical UST with a Racing Ralph eclipse.
UST is
not expensive!
Even if you only take one tube per tire into account (which is unrealistic)
they don't cost more than a normal tire/tube combination.
My UST rims don't leak. At least they leak much, much less than my eclipse-set
and even that is quite satisfactory. Sure, sealant with UST is the ideal combination.
That's why I ride my UST-tires with eclipse-valves. 30 seconds to mend a punkture.
Eclipse isn't what I would call
flawless either.
You can easily can get an imbalanced tire when all the goo dries out in one spot
(and it does dry out eventually). Punkture protection is back to normal then, too.
You need at least a second wheelset (so much for "expensive" UST) because
changing a tire on race day with eclipse is not advisable.
But hey - I love my Nokians with eclipse and will not race anything else in the near future.
R
