1 - 13 of 13 Posts
Banned
I just purchased a DCR-SR80, and I'm looking for a lipstick cam to plug into it and get some good video. Looking for 480 lines at least.
Anyone?
I've been looking around for a long time... I've trashed multiple digital cameras, and I figure:
a. I've never hit my head hard enough to cause brain damage
b. Therefore, the head must be a safe place to mount a camera
I haven't made the leap to it yet, but I really like this one: http://www.twenty20camera.com/
Banned
Discussion Starter · #3 ·
I've looked at that, but I really don't like it for the plug it uses. I'd much rather use a female composite plug to connect the camera to my camcorder.
Helmet Camera
I use the 480 line camera from http//www.helmetcamera.com. I record on a Sony GV-D200 VCR. This takes a very good video. The VCR has a IEEE1394 port, so getting the video to your computer is easypeasy. The extra couple of pounds is a training aid. lol
Me helmet cam
The camera has an RCA connector. The mike also. The power connector is a co-axial type. The camera outputs 1V P-P analog video. The Sony VCR does a A to D conversion and then records in Digital 8 format. All in all it works well ( except when I hit a tree and knock the battery loose:madmax: I'm now in the process of making a protective cover out of rigid foam. This will protect the buttons and lock the battery in position. The F550 battery only gives about 1 hour. The F750 gives several hours, but is MUCH heavier.
The Viosport Adventure Cam 3...
... is a pretty good helmet-cam. I've used it mtn biking and snowboarding and it's worked fine. Keep your expectations in check though -- picture quality is not going to be nearly as good as what you'd get directly from your camcorder.
I have a few videos on my blog if you want to check out quality.
Helmet Camera
If you bought a helmet camera, it must have been the cheapest one (Helmetcams have three models). My helmet camera takes a better picture than my Canon ELURA100 A. Its on par with my Sony TVR-340. The software and the computer that you render the video with makes loads of difference also. I have a bad assz Core-2 with killer HD's (10K RPM Raptors in raid 5). This renders video with no stutters. The Sony GV-D200 (the VCR I carry) is better than all three of my camcorders. In this world, you get what you pay for! Look at Sony's site for spec's on the camcoders vs the VCR's.
I have an "Extreme Adventure Camera 480" found here:
http://www.adventurecameras.com/cameras.html
I think pretty much everybody uses sony bullet cams, so it might be safe to assume video qualities would be pretty much the same? Maybe? I could be way off. I often am. But if true, it comes down to price and included accessories....
And make sure whichever one you pick up has a nice helmet mount that will work with your helmet! Mine came with 3 or 4 funky mounts of which none worked well with a standard vented mtb helmet. I eventually had to buy another one. Kind of frustrating.
But the quality it shoots is just fine ;)
I already rode that
I bought a Sharp 420 line and bought all the lil parts and use it like that. It works pretty good and the video qaulity is good too.
I have a Vio Sport Helmet Cam. The Model is "Adventure Cam II." $200 from pricepoint. I've barely used it but the video quality is relatively the same as my Canon Elura 100. It has a wide selection of accessories including rechargeable battery packs, many mounts and a remote for turning on and off.
Viosport also makes completely waterproof cameras....
Helmet cam crash
Neither have I :madman:
Check out www.321actioncams.com Home page video
1 - 13 of 13 Posts
