DHX Air: 14.7 oz (417g)Zip said:Who has a new Avalanche Chubie (w/ titanium spring) their Spot..??
I hear it is a lot lighter than similar set-ups, and I'm a wondering how it compares with the other rear shocks..I currently have a stock RP3.
hanks,
Rich
Here you go:trailadvent said:SC common man no CCDB it deserves to be in yr Gif![]()
boy, granted the springs are not the same weight, but the weight differences you note for the Avys (Ti versus steel spring) sure dont make me regret skipping over the Ti spring. Only 15 grams difference between the two?SCUBAPRO said:Here you go:
CCDB 450# steel spring- 830g
Avy Chubie 400# steel spring- 800g
Push'd DHXrs 450# steel spring - 740g
RP3 - 195g
SPAM: Avy Chubie 7.75x2.25 and Spot HL Seatstay for sale (AKA, 7" Travel Kit)
Yes, Ti won't save you much weight with a light weight (500# or less) 2.0 spring but they sure look nice and won't corrode in salt waterFoShizzle said:boy, granted the springs are not the same weight, but the weight differences you note for the Avys (Ti versus steel spring) sure dont make me regret skipping over the Ti spring. Only 15 grams difference between the two?
Hay FO u saying Ti is ghey whatFoShizzle thanks dawg......but who the heck buys things for looks? that is ghey
i am sorry my friend, but Ti is indeed ghey, but who cares. The only thing more ghey within MTB land is a carbon frame, a la Ibis Mojo.trailadvent said:Hay FO u saying Ti is ghey what
I gotta ask my special friend to get me a Ti sping:thumbsup:
I need it
I want it
I know it
Its not Ghey
Ya all just jealous BZ got one on his bling pimp daddy:eekster: I must have one:skep:
Ti is cool as a spring it rides nice too I can feel iti am sorry my friend, but Ti is indeed ghey, but who cares. The only thing more ghey within MTB land is a carbon frame, a la Ibis Mojo.
Well saidGhey is as Ghey does.
Scuba's right, Ti does not save much on lighter springs, but for us Clydes It's worth a Big-Mack value Meal.
feel the same way about my CCDB, I need a stiffer spring have 550 on but I need a 600 so Im gonna no pun spring for a Ti 600DHX 5.0 w/800# steel coil: 2.16lb / 980g
Avalanche Chubby w/700# Ti coil: 1.89lb / 860g
Difference: 0.27lb / 120g lighter.
As for performance, get it done right and you won't even want to keep the RP3 in the box the Avy came out of.
TA, I'd put on a steel 600# and try it out before buying the Ti just in case you don't like the 600#. 50# in spring rate makes a noticeable difference in CCDB perfomance which you may or may not like. I run 50# lighter than what CC recommends which work really well for me considering its stiff main valving.trailadvent said:Well said
feel the same way about my CCDB, I need a stiffer spring have 550 on but I need a 600 so Im gonna no pun spring for a Ti 600![]()
Cheers buddy I will try that many thanx, I'll grab my buddies 600lb spring since hes only taking his Flux on his road trip, GB coming for ya spring buddy:thumbsup:TA, I'd put on a steel 600# and try it out before buying the Ti just in case you don't like the 600#. 50# in spring rate makes a noticeable difference in CCDB perfomance which you may or may not like. I run 50# lighter than what CC recommends which work really well for me considering its stiff main valving.
I got the hi/low adjuster on the avy not long ago.Lucky7 said:Not that it really matters that much, but I measured the difference between a Romic 500lb spring and the Ti one to be .3lbs (135 grams). I run an Avy and love it. I'm sending it in for a bit of a valve tweak and the new Hi/Lo separate adjuster. It amazed me on my last off road trip by being better and better the faster/rockier things got. Now if I can improve the low speed stuff a little bit, it'll be on! Oh yeah, I even got one for my trail bike. Probably way overkill for an all mountainish bike, and admittedly I had UGI, but I can't imagine it'll be a hindering factor on the trail. Now it's on to seeing if I can get one on my 4x/DJ bike.....I might have a problem.....
