1 - 12 of 12 Posts
EAT MORE GRIME
(ノಠ益ಠ)ノ彡┻━┻
yes
I have two, one on my 1x1 and one on my SS road bike
very smooth, reliable, long lasting, goes through muck and pretty much maintenance free. worth the coin.
I was replacing basic shimano SS cogs so anything is better than those, but I have zero problems with ENO in fact they are butter smooth and I love them
I have three, one on the 650b I just built (non-ecentric) and two ecentric hubs one on my Fixie roadie and another im about to build to convert my CX to SS..
great hubs, one I had to replace the bearings in but I got it used after putting in enduro bearings it's been great.
on the plus side bearing replacment was super easy and the bearings were not to many $$..
the WI freewheels are sweet to!
Yep, and if you have different ratios on the flip/flop side you can carry a 19mm cone wrench (v. light!) and use that for adjusting on the road. Its very easy to over tension but you get the hang of it pretty quickly.
I've had one for several years now, and my experience is the same as localhost.
It takes a little experience learning how to adjust it best, but they just work and keep on trucking. Using one might require a half link for certain gearing, but there are high quality half links you can use. You can sometimes have slipping problems using one on a titanium frame just because it can't grip the frame material as well.
1 - 12 of 12 Posts
