I say medium, main reason because your medium DB Fits you, so why would you want to go 1.5 inches smaller when they are very close to being the same Geo?
using a 60mm with a low riser bar rightnow, going to an 80mm with a flat barAZ.MTNS said:How long is the stem you are using/going to use ?
so inseam is the magic number huh?AZ.MTNS said:18 inch size if your inseam is bike inseam .
The more I think about it the more I like the idea of the 16.5 for you just because of the standover. See the other topic for the explanation.wildkyle90 said:the top tube length is 1/2 an inch shorter than my db for the 16.5 inch, with only an inch of standover difference
Only part of the equation , you have to be able to straddle it so standover is one component . Reach to the bars is another , thats why I asked about stem length . Effective top tube/cockpit length is probably the most important component . Cockpit can be tweaked with stem and bars .wildkyle90 said:so inseam is the magic number huh?
Welcome to the growing family of Sette Owners.wildkyle90 said:Just pulled the trigger, got the 16.5", and now i wait!
