go dhx if u want more adjustability, but if u like the rc and just need a shock then get the rc push'edebfreerider510 said:a dhx should work, u could also get your vanilla re built by www.pushindustries.com
AVY!!!!!Ace_Jellyfish said:christmas is coming around and i need a new shock. the resivor body on my vanilla rc is stripped. i was thinking of getting a dhx but idk if it will fit my 03 gemini 900? what do you think the best shock for my bike is?
will a dhx fit my bike though? anybody know?MX 887 said:hmm since you can't push it i would say dhx
I'd go DHX if you're pedaling on it. I've got one on my Mini-Free and it's done me well. What's the eye-to-eye measurement on your shock? Measure from the middle of one eye to the middle of the other. That's the measurement you need to find out if you can fit a DHX.Ace_Jellyfish said:will a dhx fit my bike though? anybody know?
im talking about it hitting my framePhoto-John said:I'd go DHX if you're pedaling on it. I've got one on my Mini-Free and it's done me well. What's the eye-to-eye measurement on your shock? Measure from the middle of one eye to the middle of the other. That's the measurement you need to find out if you can fit a DHX.
i believe they make a 7.875x2.25 version, ill have to checkdamion said:It should not be a problem, unless it is a small frame. I have an XL 2003 Gemini, with a 5th coil.
The stock size is 7.875x2.25.
My shock is a 8.0x2.25", and it BARELY fits in the long travel position.
yeah they do, http://www.ride-this.com/Fox_Racing_DHX_5_0_02-020280003.htmlurbanfreerider666 said:i believe they make a 7.875x2.25 version, ill have to check
well i have a medium and im thinking about getting a DHX probably and they have huge resivors, i think theyre bigger than 5ths? i dont want to buy a shock to only have it dent my frame when fully compresseddamion said:It should not be a problem, unless it is a small frame. I have an XL 2003 Gemini, with a 5th coil.
call up fox and just ask them, even if someone gives a strait answer, u should still call them, im pretty sure that they make remote resivoirs so u can mount it on the frame somewhere, if not then the only other option is to get a different shock, if it comes down to taht try the 5th cvt5, one of my friends has one of them and he loves itAce_Jellyfish said:well i have a medium and im thinking about getting a DHX probably and they have huge resivors, i think theyre bigger than 5ths? i dont want to buy a shock to only have it dent my frame when fully compressed
At the time, it was not available. (out of stock)urbanfreerider666 said:i believe they make a 7.875x2.25 version, ill have to check
