I don't think there was ever a RockShox fork with a titanium crown. The early forks had magnesium crowns and the current one's have aluminum crowns. Carbon fiber crowns and steerers have also been used.
Confirmed, I had a Mag 21 SL. Ti hardware only. I've known Ti steerers, springs, and stanchions on production forks but if anyone made an aftermarket Ti crown for a Mag 21 it's buried deep in someone's old parts bin.Yeah. I thought the only sl was the mag 21 sl and it only had ti hardware (bolts and bosses).
the mag 20 was the older version, the mag 30 the cheaper version and neither had an sl version. But could be wrong of course.
You seem to be comparing Quadra to Mag 21 SL Ti. You do not drop 200 grams with some small titanium BS on a fork. 🤣👊View attachment 1963018
Rock Shox Mag 21 SL Ti – Retro Forks Bike
retroforksbike.pl
Ti model listed as 200g lighter
In the link the Mag 21 is listed at 1225g the mag 21 SL is listed at 1043g, so 182g differenceYou seem to be comparing Quadra to Mag 21 SL Ti. You do not drop 200 grams with some small titanium BS on a fork. 🤣👊
You appear not to have clicked on the link or done any reading whatsoever.You seem to be comparing Quadra to Mag 21 SL Ti. You do not drop 200 grams with some small titanium BS on a fork. 🤣👊
Thanks for chiming in with the opinion though. Really added to the discussion.Mag-21 SL Ti had a unique crown that was further machined on the underside. It was aluminum but lighter (and less stiff) that the normal Mag series crown. Its obvious if you look at the underside
Yeah, but it would probably make the fork flex even more, which was kind of the trend, make the fork as noodlely as possible.Gen 1 SID had a Ti steerer option, that's the closest I can think of for early stuff. I would think machining a Ti crown would be insanely expensive because of material loss for a quality product.
