08 Nomad....Eventually going to be puting a 36 talas and a DHX coil on and I just want some input on which part I should put on first since I am not buying at the same time.....so which upgrade should I do first? Thanks!!
At least IMO. The Domain is heavy but it works great for a Nomad. I do not believe that the Float is a good match to the Nomad. Get a piggyback rear shock...like the DHX coil you mentioned...and you'll have a much better Nomad. When weight and some money to burn becomes more of an issue, replace the fork. The DHX coil will give you so many more tuning options across the board. The Domain will perform excellently.sweetchiba51 said:Yes it is a complete...domain front, float rear....
