Which bike/frame for marathon XC would you recommend that supports 2 bottles in the main triangle and might be set up with AXS or XTR 1x12 ?
Complete bike is desirable, can make build by myself although will cost more. Weight weeny, 175cm, 86cm inseam, 69kg, occasional racing, technical, absolutely in-love with single tracks
Desired component spec:
Fox 34SC 110~120, might go with 32SC 100 as well with the right frame/combo
SRAM Eagle AXS or XTR 1x12
Lightweight carbon wheels 25mm inner, should be less than 1500gr
Dropper 100~125cm
Candidates:
1. Canyon LUX - all XTR models are sold-out or unavailable
2. Orbea OIZ - most promising at the moment, TR model no love for the wheelset (old grudge for Mavic)
3. Bulls prototype (2020), four bar might imply a low efficiency platform (yet smooth and active) unless "propedal" engaged
4. Spesh EPIC - no, rear suspension opening upon impact is annoying to me as it resembles a snake bite / too low pressure in the rear tyre
5. Scalpel - no, too racy, small second bottle on the seat tube
Dropper 100~125cm
Candidates:
