I've had a dirtbag for a while now, and my roomate got a Blindside when they came out. Between the two, I would go for the Blindside.
I like my DB, but since you already have a BottleRocket, I think you'd find a lot of overlap between the two.
They both run 2.25" stroke shocks, but the DB runs a higher ratio helping it to soak up small bump a little easier, but the 6.75" of travel feels pretty short in some extended rough sections.
My roomate's Blindside is running a Roco air shock, and it functions great. I like the geo, and a medium frame fit's my 6'2" quite nicely. His Blindside is also built up a little lighter than my Dirtbag while we run a lot of the same parts.
Blindside medium
888 RC3
Roco Air
Revolution wheels/Minion DHF/DHR combo 2.5
x9 rd X7 shifter
RF ride cranks/Deity pedals
Sram 950 casette
Deity bar
Code brakes
Transition house Chainguide
CK 1.5r headset
No floating brake option (used it for a while, took it off)
42.7
Dirtbag
66 RC3
Fox DHX 5.0 /w 650lb spring
729/hope front/ 729 revolution hub rear Dual Minion DHR 2.5s
09 Saint shifter/Short Cage RD combo
Deity Vendetta cranks w34t deity ring/ DMR V12 pedals
Sram 990 cassette
Deity bar
Code brakes
Transition house chainguide
43.9lbs
his isn't much lighter, but consider he has a heavy wheelset, a 888 and nearly 2" more travel than mine is pretty sweet.
Also, I think the Dirtbag is getting phased out as is if I am not mistaken. Could be a good deal if you can find one at the right price. You're not likely to hurt those frames.
Blindside medium
888 RC3
Roco Air
x9 rd X7 shifter
Sram 950 casette
Deity bar
Code brakes
CK 1.5r headset
42.7
Dirtbag
66 RC3
Sram 990 cassette
Deity bar
Code brakes
43.9lbs
