So I'm in need of a fairly inexpensive long travel bike and I think I have the IH 7 point at the top of my list based on value and performance. Randall Scott has three of them, all within a couple of hundred of dollars of each other. Based on specs, which one would you guys choose:
2008 7Point $1899 ----------------------------------------------------------------
Frame: 7" TRAVEL dw-link FREERIDE FRAME, 1.5 HEADTUBE, 150MM X 12MM THRU AXLE HUB, 83MM BB SHELL, REPLACEABLE DERAILLEUR HANGER
Fork: MARZOCCHI 66RCV, 180MM TRAVEL, W/ 1.5" STEERER
Rear Shock: FOX VAN R COIL, 8.75"X2.75", 15/17" 300LBS SPRING, 19" 350LBS SPRING
Front Derailleur: SHIMANO SAINT, 34.9MM CLAMP
Rear Derailleur: SRAM X.7 MID CAGE
Shifters: SRAM X.5 TRIGGER
Brakes Levers: AVID JUICY 3
Brakes: AVID JUICY 3 W/ 203MM FRONT & 185MM REAR ROTORS
Chain: HG53
Crankset: FSA GRAVITY MOTO X, 170MM
Cassette: SRAM PG-950, 11/34T, 9 SPEED
Pedals: CRANK BROS 5050X PLATFORM
Bottom Bracket: FSA MEGAEXO, 83MM
Headset: BIG FAT PIG 1.5
Saddle: WTB PURE V RACE
Seat Post: FUNN SPLINED V3, 30.0MM
Handlebar: FUNN 318, 30MM RISE, 710MM WIDTH, 31.8MM CLAMP
Grips: N/A
Stem: FUNN RIPPA 1.5, 31.8MM CLAMP
Tires: MAXXIS MINION F DH 60A COMPOUND, SINGLE PLY CASING, 2.5" FRONT & REAR
Wheelset: ALLOY DH, SEALED BEARING, 110MM X 20MM THRU AXLE, 32H/ALLOY DH, SEALED BEARING, 150MM X 12MM THRU AXLE, 32H/SUN RIMS MTX S-TYPE, 32H/DT/SWISS CHAMPION 2.0
Weight: 42.9 lbs
Color: CHARCOAL SATIN
2007 7Point3 $1699 ------------------------------------
Frame: dw-7, 7" TRAVEL FREERIDE FRAME, 12mm THRU AXLE x 150mm SPACING, W/REPLACEABLE DROPOUT, W/INT'L DISC BRAKE MOUNT
Fork: Rock Shock Domain 302 Coil , 185mm travel
Rear Shock: Fox VAN R 300x3.24
Front Derailleur: Shimano SAINT FD-M806, TOP PULL
Rear Derailleur: Sram X.7, Mid Cage
Shifters: Sram SX.5 TRIGGERS
Brakes: AVID JUICY 3 (Front: 8"rotors, Rear: 8" rotors)
Chain: Sram P-951
Crankset: FSA Moto X, 36/24T
Cassette: SRAM PG-950, 11/34T, 9-SPD
Pedals: CRANK BROS 5050X, COLOR; BLACK AND SILVEr
Bottom Bracket: FSA INCLUDED W/ CRANK
Headset: Cane Creek Integrated system headset w/ FSA Top Cap
Saddle: WTB Pure V Race
Seat Post: Funn V3 Splined System 30.0mm X 300mm
Handlebar: FUNN 318 710mm, 30mm RISE Fatboy
Grips: Velo VLG-408 black
Stem: FUNN Rippa - 1.5 Steerer Clamp, 31.8mm
Tires: Maxxis MINION DHF, 26x2.5
Wheelset: Sun Rimes S-type 559x34mm
Weight: 41.27 lbs 17"
Color: Graphite
2007 7Point5 $1999 ---------------------------------------------
Frame: dw-7, 7" TRAVEL FREERIDE FRAME, 12mm THRU AXLE x 150mm SPACING, W/REPLACEABLE DROPOUT, W/INT'L DISC BRAKE MOUNT, 1.5" HEADTUBE, SIZE = 15/17/19", W/ ENDURO MAX BEARINGS
Fork: Marzocchi Bomber 66 RCV
Rear Shock: Fox DHX 3.0 Coil
Front Derailleur: Shimano Saint, Top Pull
Rear Derailleur: Shimano Saint
Shifters: Shimano Deore XT
Brakes Levers: Avid JUICY 3
Brakes: Avid JUICY 3 (Front: 8"rotors, Rear: 7" rotors)
Chain: KMC-HG53
Crankset: Race Face Evolve DH 36/24T W/ e.thirteen bashgard
Cassette: SRAM P-950
Pedals: CRANK BROS 5050X PLATFORMS
Bottom Bracket: Race Face x-Type FR/DH
Headset: Cane Creek IS w/ FSA Cap
Saddle: WTB Pure V Race, SATIN STEEL RAILS, COLOR: BLACK
Seat Post: Funn Splined Post V3, 30.0 x 300mm, COLOR: BLACK
Handlebar: Funn Fatboy 30mm Rise, 8 Deg Sweep, 710mm Width
Grips: Funn Combat Grips, LOCK ON, COLOR: BLACK
Stem: FSA ST-DH-300, 1.5, 60mmX10Deg, 31.8mm
Tires: Maxxis Minion DH F, WIRE BEAD, FRONT: 26X2.5, REAR: 26X2.5
Wheelset: Sun MTX S-TYPE rims with alloy hubs
Weight: 43.45 lbs 17"
Color: Satin
Chain: HG53
Grips: N/A
Weight: 42.9 lbs
Chain: Sram P-951
Color: Graphite
Chain: KMC-HG53
Color: Satin
