I have been riding a Pugsley for a couple years in the cold Minnesota winters, and I've always had problems with the brake calipers leaking oil around the piston seal. It seems to happen at any temperature, and I do not know if it leaks worse as the temps drop. It just leaks all the time. Now the leak has gotten bad enough that the oil is dripping off the caliper at the end of a ride, and it's time to finally do something about it. (I know, should have looked into it WAY sooner, but I am the King of Procrastination, so I didn't) The leak has gotten progressively worse as time has gone on. I almost didn't even notice it in the beginning.
I am using out-of-the-box Hayes Stroker Trail hydro brakes, and I've never bled them. They've worked great from day one... other than the annoying leak. I have only ridden the bike in the summer one time for about 20 minutes, and it was on sandy singletrack. Other than that, the bike has only been on nice clean snowy singletrack through the woods. Never been on a road with salt or sand. No commuting. Still have the little nipple-fuzzy things on the endomorphs, apparently soft snow doesn't wear out tires very fast.
I want to buy different brakes for this bike, but I don't want to buy another pair that will have the same, or some other, problem. Here's my question: Which brakes have people had good luck with for riding in the winter, and in cold temps? I will most likely never ride this bike in the summer, but I will ride in the winter in any temp, and it can get below -30F around here. It seems like it's -10F for half of the winter. Also, I am not concerned so much about braking power as I am modulation. It doesn't take much power at all to lock up the tires on snow, I'd rather have a good feel for the trail. I ride almost exclusively on singletrack trail, sometimes with deep snow, which comes into play when you're making snow angels along the side of the trail after a dismount, and the brakes have now been buried in a snow bank. For this reason I would like to stay away from all the moving parts that mechanical brakes have.
I understand that I could probably repair these brakes and continue to use them, but I would rather just buy the right tool for the job and be done with it. I can repair these brakes and sell them, or use them on another bike, or just hang onto them for spares.
I have three different brands of hydro brakes on my other bikes, so I have no "favorite" brand. I don't care what brand the right one is, I just want something that will do the job and cost is not a factor.
I spent several hours searching through the forums, and so far the most useful information that I've come up with is that the DOT fluid seems to work better than the mineral oil fluid. All the other reviews and information seems to relate to usage in other than winter conditions, but I'm looking for a brake for winter use only.
Any words of wisdom from actual cold-weather, winter users would be great.
