I like new Orbea Alma!!! wow!!!
Hey, if you're Scape is in a 20", you just found someone to unload it on when you upgrade!!! Orbea's site says the Alma and the Scape weigh in at the same weight, which would either make the Alma heavy for a carbon frame, or the Scape light for aluminum, I would think!Spin Cycle said:I have a 2005 Orbea Scape Scadium Frame riding it about one month and i love it also have a few mile on on of there carbon road frames so just waiting for my LBS to get one then??? time to upgrade!
http://www.orbea.com/ingles/cuadros.php?tipo=2&familia=8&cuadro=14
Hi Codman,CODMAN said:Hi PY,
so you are leaving the realm of Ti??![]()
Come over to the dark side of carbon....
Soory, can't help you out! I just wanted to say hi!
Talk to you soon!!!
Yeah, you have a good point there. I didn't look to far into geometry. I've also heard nothing but good things about carbon's ability to absorb shock coming up through the frame.xavier lord said:maybe your right, but how about the geometry is not the same with the aluminium frame, i think its better handling with the alma and it absorbs much better too
I'm on a 20" and it weighs 1391 gram so it's alittle heavier than the 1300 grams on therepsinsyd said:Hey, if you're Scape is in a 20", you just found someone to unload it on when you upgrade!!! Orbea's site says the Alma and the Scape weigh in at the same weight, which would either make the Alma heavy for a carbon frame, or the Scape light for aluminum, I would think!
Just my .02$![]()
The Orbea site is saying 1200g for the 18" for both the Scape and the Alma. Either way, a 20" frame weighing 3.0602lbs is pretty light!Spin Cycle said:I'm on a 20" and it weighs 1391 gram so it's alittle heavier than the 1300 grams on there
wed page albeit for a 18" frame
http://forums.mtbr.com/showthread.php?t=141029psinsyd said:The Orbea site is saying 1200g for the 18" for both the Scape and the Alma. Either way, a 20" frame weighing 3.0602lbs is pretty light!
Do you like the ride and quality of the frame so far? It seems like an ultra-sweet frame!![]()
Yep, I remember that thread!! Man, is that sweet! Once the season starts, I'll finally get around to posting pics of my Kona.Spin Cycle said:
