1 - 9 of 9 Posts
Hey guys the brakes on my road bike barely work at all and it is time for me to get some new ones. I would like to keep my brake levers and shifters if possible, and only change the caliper set.
Does anyone know know which brakes would fit with the levers I have? I bought this road bike off of Craigslist so I don't know the exact components but here are some pictures.
I was thinking of getting the Avid Single Digit 7, does anyone know if those would work with my brake levers?
I don't want to spend more than $300 I use this bike for commuting and not going off road mainly, any advice would be much appreciated.
Discussion Starter · #3 ·
I was trying to repair these brakes a while back and accidentally broke them by losing one of the parts.
Plays with tools
it looks like you have the mini V style brakes which are awesome for use with road levers on cross bikes. However they are meant to work on the cable pull of a cant lever not a V and this is what is likely causing your problem. Avid single digit series brakes were my favorites in the days of rim brakes, I wouldn't get the 7's for a craigslist clunker though.
A lot of the Shimano brake levers had adjustable cable pull built into them. Might be worth playing with the shims in there to see if that helps your problem out.
The shoes may have hardened up a bit at the breaking suface. When the rubber gets hard it won't bite the rim. A fresh set of shoes won't cost $30 let alone $300!
Also make sure the angle of the shoes mate with the rims. You might also want all the parts to the system!
New brakes are in order then, your brake levers are for V/linear-brakes. Your current setup is not an ideal brake combo(as customfab astutely noted). Grab some tektro, shimano deore/lx or SD 5/7 brakes, whatever is best bang for the buck.
1 - 9 of 9 Posts
