That is too much money for me.
Wouldn't the steep head angle and long reach be better for BC on the Giant, I don't know a crazy amount about geometry but that's what I thought. would the smaller stack height be the bad thing for BCTroy. It will likely climb better and handle BC chunk better. You may want to upgrade the fork before long though.
I really can't pick between the two and they both would have great supportI don't think you can go wrong with either. I would choose based on one of the following:
Which one has better dealer support in your area?
OR
Which one do you hope we will tell you is the better option?
If its a wash I'd personally pick the Troy...
You don't want a steep head tube angle for BC. Look up the recent Pinkbike review of the Giant. The split pivot suspension on the Troy is pretty sweet too.Wouldn't the steep head angle and long reach be better for BC on the Giant, I don't know a crazy amount about geometry but that's what I thought. would the smaller stack height be the bad thing for BC
The X 3 has a Rockshox Yari RC fork which is upgradeable to the charger damperThe X 3 has a RS 35 fork. Which is junk because of the Motion Control 15+ year old plastic 'damper'.
Which has no small bumper high speed compression damping. And no adjustment for high speed damping. You'll bounce with every small rock/root impact. "High speed" refers to the impact speed response not the bike speed.
More- the 'damper' gets quickly overpowered with bike speed. Then you have no damping at all and bounce around when you're going fast and hitting bumps. Loss of control and heavy braking or crash are the options. You do get an adrenaline rush from the danger.
Plus RockShox made the 35mm stanchion interior dimension different than their better forks. You can't buy a better Charger damper to upgrade it.
So it's a dead end total replacement choice.![]()
Rockshox 35 Gold RL upgrade-able?
I thinking of picking up a 2020 Whyte 901 that comes with the Rockshox 35 Gold RL 130mm fork. From what I can tell it does not have adjustable compression, just lock out, but does take tokens and has adjustable rebound. This would just be my backup bike, but does anyone know if it can be...www.mtbr.com
The X 2 is $3500/4300CA. You get a decent fork. Fox 36 with a Grip damper. I'd take an Occam H30 for the same money.
The Troy has a 35mm stanchion RS Revelation fork. It comes with the Motion Control damper as above. But the stanchion interior dimension is the same as a Pike. So you can upgrade the crap damper to a Charger level. And that is an immediate change before you even ride it. I'd buy the damper before taking delivery. Or look for a used fork and sell yours as a new takeoff. My fork choice would be a Manitou Mezzer.
I meant slack, the lower the degree that slacker is right. So wouldn't that mean it is better, I have always heard that the slacker it is the better it is for steep terrain?You don't want a steep head tube angle for BC. Look up the recent Pinkbike review of the Giant. The split pivot suspension on the Troy is pretty sweet too.
See post 10 above.I meant slack, the lower the degree that slacker is right. So wouldn't that mean it is better, I have always heard that the slacker it is the better it is for steep terrain?
So the slacker head angle on the Trance would be better for the north shore?See post 10 above.
Yeah I didn't realize that the brand new one is very slack. I was under the assumption that you were referring to the 29-er Trance X.So the slacker head angle on the Trance would be better for the north shore?
So would you still choose the Troy for the north shore or would you pick the Trance?Yeah I didn't realize that the brand new one is very slack. I was under the assumption that you were referring to the 29-er Trance X.
I don’t know. I would have to ride each of them to decide. The yari and Deore on the Giant are pretty good for that price. You can upgrade the fork easily enough and it’s a good chassis.So would you still choose the Troy for the north shore or would you pick the Trance?
If I were to upgrade the fork, I would not buy a whole new fork I would probably just get the charger 2.1 damperI don’t know. I would have to ride each of them to decide. The yari and Deore on the Giant are pretty good for that price. You can upgrade the fork easily enough and it’s a good chassis.
Yeah that's what I was getting at.If I were to upgrade the fork, I would not buy a whole new fork I would probably just get the charger 2.1 damper
