Stopped by Performance Bike shop on a lunch break and was taking a look around. Guy recommended me a 2009 Fuji Mt Fuji Pro Carbon Fiber (21") bike that was on sale for $1299. He said it was a very good price for the specs. But I've been leaning towards 29" bikes after reading about them and they showed me an 2010 Access 9.7 (19") frame bike for $899. I went back after work and test rode both of them in parking lot. I think I fit both bikes comfortably. I'm 6'2 with 32" inseam, and havent been riding for about 10yrs. I plan on doing just light bike trails through forest preserves so Im not sure which bike I should get.
The Fuji felt very maneuverable, but it also seemed i was hunched down more (or maybe its because I haven't been on a bike for 10 yrs?). The Access 29er was a bike I could sit up more and it feels like a easy cruising around bike, it also seemed a lot faster than the Fuji.
I expected the Access bike to weigh a lot more, but it wasnt that much heavier than the Carbon one so I'm not sure which bike to really go with. Is the Fuji bike worth the extra $300 over the Access Bike?
The Fuji bike is defiantly at the top of my budget, and I don't intend on upgrading either bike if I get them, so I'm not sure if I should spend a little more upfront now.
Specs of the bikes
Specs of the bikes
Mt Fuji Pro
Main frame Monoque C-4 carbon with custom uni-directional carbon strands, Integrated aluminum cupped head tube, Double water bottle mounts.
Rear triangle C-4 carbon stays with shaped ride tuned Energy Transfer Chainstay, cold forged dropout with replaceable hanger and CNC Disc mount only option
Fork Rock Shox Recon SL Air, 80mm Travel w/ PopLoc Remote
Crankset NEW Shimano SLX, 22/32/44T Alloy Outer Ring
Bottom bracket Shimano Exterior Bearing System
Pedals Xpedo MF-3 Clipless
Front derailleur NEW Shimano SLX, 34.9mm
Rear derailleur NEW Shimano SLX Shadow
Shifters NEW Shimano SLX Rapid Fire, 27-speed
Cassette Shimano CS-HG50, 11-34T 9-speed
Chain KMC HG-73
Front hub NEW Shimano SLX Sealed Bearing Centerlock Disc, 32H
Rear hub NEW Shimano SLX Sealed Bearing Centerlock Disc, 32H
Spokes 14G Stainless Steel
Rims Mavic XM-317 Disc, 32H
Tires Continental SpeedKing 26 X 2.1" Foldable
Tube CST Presta
Brake set NEW Shimano SLX Hydraulic Disc, 180/160mm Centerlock rotor
Brake levers NEW Shimano SLX
Headset Ritchey Logic Zero Comp 1 1/8" Press Fit Integrated, 30mm spacers
Handlebar Fuji Pro Riser 15mm double butted aluminum 31.8mm
Stem Fuji Pro Alloy oversize, 1 1/8"
Tape/grip Fuji Lock-On Kraton rubber
Saddle WTB Custom Rocket V Comp
Seat post Fuji Pro forged Alloy micro adjust, 350mm
Seat clamp Fuji Superlite Alloy, 34.9mm Laser Etched
Weight, lb./kg. 25.50/11.57
2010 Access XCL 9.7 29" Mountain Bike
BOTTOM BRACKET: TruVativ Giga X Pipe XR
BRAKES: Avid Elixir 5 Hydraulic Disc w/ 185mm front, 160mm rear
CASSETTE: SRAM PG-950, 11/34T, 9-speed
CHAIN: KMC HG73 1/2" 11/128" 106L
CRANKSET: TruVativ FireX 3.3 aluminum, 22/32/44T
FORK: Rock Shox Tora SL 100mm travel
FRAME: 6061 Aluminum
FRONT DERAILLEUR: SRAM X.7, 34.9, top-pull
GRIPS/TAPE: Velo Oury
HANDLEBAR: MTB, butted aluminum, 710mm, 25mm rise
HEADSET: Cane Creek Semi-integrated
LEVERS: Avid Elixir 5 Hydraulic Disc
PEDALS: Wellgo WPD-801, chromoly axle
REAR DERAILLEUR: SRAM X.7, long cage
REAR SHOCK: NA
SADDLE: Velo
SEATPOST: 7075 Aluminum, 31.6, 350L
SHIFTERS: SRAM X.7 Trigger
STEM: Forged Alloy 4-bolt, 7° rise, EXT:15"=90mm,17"=100mm,19"=110mm, 21/23"=120mm, 31.8
TIRES: Schwalbe Albert HS 29 x 2.1"
WHEELSET: Rims: Mavic TN 719 Disc, 29", 32H; Hubs: CNC alloy, disc, sealed, 32H
