this is what I'm wondering... does the pushloc or X-loc or whatever it's called on the Reba XX 29 allow for compression adjustment, or is it just full on (locked) or full off and no in between ??ncfisherman said:I consider poploc/pushloc to be a downgrade since there is less adjustability(unless you have poploc adjust).
No clue on the first part, but the X-Loc barrel adjuster (just like you'd find on a shifter) lets you set up compression along a wide range. When the fork is locked out, I can get between 10mm (full on) and 40-50mm (loose as possible) of travel. It also helps stiffen it up for low speed compression when not locked out. Pretty amazing design. I'm a fan of the XX forks.MI_canuck said:So can anyone answer whether the Team damper is the same as the XX ?? Both are 'Blackbox' Motion control from what I can see. Aside from the remote, are they the same?
cheers
thnx
