Magura MT2 with BAT- i've just performed a bleed. I went to pump the brake once it was all back together, and then fluid started pouring out everywhere! I took off the lever completely and started to pump it again and i found there's a hole where the leaver connects to the handlebar, and when i pump the lever it bubbles and secretes oil. see pics below:
Not sure what to do next? Its definitely not leaking from any of the bleed screws, just the hole depicted below. The whole is suppossed to be there so it must be leaking internally? Any help will be very much appreciated!
Here's once i cleaned it up again, you can clearly see the hole:
Cheers!
Cheers!
