Guess you'll be getting another email from me...MuleFut's are about all that's left.
I have most -- but not all -- of them...![]()
DT Swiss, arguably the biggest rim mfr, is still showing their fat-rims. Did they stop production?
That is far from idealIf you’re only running a 4” tire, the Duroc 50s should work. Universal had them in stock last time I checked.
Plenty of people do it with the 3.8s and 4.0s. I believe pretty much all the 65mm rims are discontinued and so people started using the 50mm ID rims instead of the 80mm.That is far from ideal
they're on a boat in the Pacific
You are giving up a lot of sidewall support, this affects handling significantly.Plenty of people do it with the 3.8s and 4.0s. I believe pretty much all the 65mm rims are discontinued and so people started using the 50mm ID rims instead of the 80mm.
There were a few threads here in the past discussing it. I’d have to dig for them though.
I agree. Wasn’t saying it’s optimal, was just throwing out that it’s an option people are using. The only options now that I know of are 50mm and 80mm. Guys that run 3.8s or smaller 4.0s usually opt for the 50s if they ride mostly trail.You are giving up a lot of sidewall support, this affects handling significantly.
