And a word of caution about oils: most chain lubricants should not be considered "oil". If it contains parafin, you shouldn't lubricate your freehub with it.Freehub lubricant can depend on several factors, but generally you have two choices. Oil or grease based lubricants. these choices can be based on the type of freehub you are using and perhaps level of performance.
With bearings the lubricant used is important. Everywhere else is more a matter of not having lubricant that will result in dirt build up on the surfaces, as with the chain. The deraileur, bottom bracket, pedals, and wheel hubs are where I focus my attention. Lots of money to be made by selling a few ounces of magic lubricant to the bike market which is why the confusion. Check with your local bike shop and see what they use on a day to day basis.There are so many different types of grease, oils, etc on the market. How do I know which one to use in a certain situations and where to put it, such as bearings or threads. Thanks for any tips or advice in advance.
There's no doubt these are high-quality lubricants that are designed for high temp, extreme pressure industrial, marine and automotive specialty applications, but do we need the variety and in one case, the expense of these for a bike? The Mobil XHP is common inexpensive mainstream bearing grease that can cover every bearing on a bike. Almagard 3752 is about twice the price of the Mobil and it meets the same design specs.My take:
Basically, #1 Mobil XHP 222 is for mid-level bearings and general applications
#2 Almagard 3752 is a super grease for headset bushings and bearings
#3 is specifically Isoflex Topas NB 52 a very high quality and sophisticated German grease
The Mobil grease can be used for many more applications than simply bearings, as mentioned. Moly greases are for bearings, but are also recommended in slow or oscillating motions such as those seen in universal and CV joints (or pivots, pivot bolts etc.). It is a great grease for a younger person without much money for general use on every component on a mountain bike. I also use it for the bearings and handles in my fishing reels. As for the Almagard, watch a video of the particular benefits it may offer. It is extrememly resistant (doesn't break down) and resilient (goes back into shape) to pressure from friction, water etc. Great for the turning motion of the headset; much more so than the Mobil grease. Worth the extra $$.... imo.There's no doubt these are high-quality lubricants that are designed for high temp, extreme pressure industrial, marine and automotive specialty applications, but do we need the variety and in one case, the expense of these for a bike? The Mobil XHP is common inexpensive mainstream bearing grease that can cover every bearing on a bike. Almagard 3752 is about twice the price of the Mobil and it meets the same design specs.
In fact, it's interesting in the separation of the recommended application because in the industry, these two greases are interchangeable and meet the same design standards.
Onyx Hubs recommends Kluber Isoflex for the Sprag Clutch, but it's not the Topas NB. I think its LDS 18.
Maybe I'm missing something here, but what attributes does Almagard offer that the Mobil does not?As for the Almagard, watch a video of the particular benefits it may offer. It is extrememly resistant (doesn't break down) and resilient (goes back into shape) to pressure from friction, water etc. Great for the turning motion of the headset; much more so than the Mobil grease. Worth the extra $$.... imo.
Is that your answer?Much more resistant to water and friction.
