I've used Dirtlabs a couple times. For a fork only it's been around $250 with shipping both ways.
Central NC.where are you located?
Perhaps you need to define 'service'. An LBS should be able to perform basic fluid service for both forks and shock. Full rebuilds with dampener service will need more specialized care.I’m in need of getting my 2020 fox fork and shock serviced.
I would think with a 2020 fork it's not likely that it's going to need major work.Perhaps you need to define 'service'. An LBS should be able to perform basic fluid service for both forks and shock. Full rebuilds with dampener service will need more specialized care.
Perhaps you need to define 'service'. An LBS should be able to perform basic fluid service for both forks and shock. Full rebuilds with dampener service will need more specializedThere’s nothing major wrong with either the fork or the shock, aside from a small oil leak out the damper side dust seal on the fork that I found on my last ride. The suspension does have about 200 hours of mostly downhill and enduro type of riding. It’s also on an ebike, and I’m not a small guy. I figured it’s time for some maintenance. I’m thinking something like the fox factory service for both that they recommend every 125 hours.I would think with a 2020 fork it's not likely that it's going to need major work.
(I actually would think it's not likely it needs any work at all unless the OP is putting in a lot of hard miles.)
Yeah, with a few hundred hours, probably makes sense to at least get a look at it.There’s nothing major wrong with either the fork or the shock, aside from a small oil leak out the damper side dust seal on the fork that I found on my last ride. The suspension does have about 200 hours of mostly downhill and enduro type of riding. It’s also on an ebike, and I’m not a small guy. I figured it’s time for some maintenance. I’m thinking something like the fox factory service for both that they recommend every 125 hours.
I don’t know what happened with the quote above, and can’t seem to fix it, so the mods can delete the post above this one (#11) if they wish.
I tried that, but no matter what I did it wouldn’t take my reply out of the box with the quoted post.Yeah, with a few hundred hours, probably makes sense to at least get a look at it.
If you want to edit your post, click on the three dots in the upper right corner of it.![]()
Your comment was inside the [/QUOTE]I don’t know what happened with the quote above...
Thanks. I’ll check them out.North Carolina, Find Your Line in Asheville.
