Where to find 650B Tubes?
8405 Views 16 Replies 11 Participants Last post by  hphrush
I know a lot of people are running tubeless, and I may in the future, but I am going with tubes to start. Where are you guys getting your 650B tubes? Also, is there a certain size within the 650B tube category that I need to get? I will be using Blunt rims and XC Fire Pro 2.1 tires.
1 - 17 of 17 Posts
So I finally came across these. Before I buy, I want to make sure this is what I need.
http://aebike.com/page.cfm?PageID=30&action=details&sku=TU6870
as opposed to these which seem to be a lot thinner and maybe road tires?
http://www.bikebling.com/Michelin-A...resta-Val-p/michelin-aircomp-tubes650b-pv.htm
So which one is the right size?
26" tubes work fine on a 29er, so using on an designed for girls 650b shouldn't be a prob.
I have even used 24" tubes on my 29er, but that didnt work so well.
the first link is correct. the second its a 650c not 650b which is found on alot of TRI bikes.
a standard 26" tube fits like you wouldnt believe.
i was told that and believed it would be difficult and a bit sketchy but i got a flat and only had a 26" tube and have been riding for 25-30 miles with no issue and installation was nothing but ordinary.
26" tubes work perfectly. :thumbsup:
Cheers,
KP
Thanks guys. I considered using 26" but was skeptical. Think I will give them shot. Also, thanks for the smart a** comment flargle. Glad you get off on helping advance the sport of mountain biking,:thumbsup:
I use 26" Specialized Turbo tubes in my 29er wheels (the ones that aren't tubeless). Light, pre-talced, fit in all my wheel sizes.
I use the same tubes on my 26" currently. Think I will stick with them on my 650B.
Then you are all set! :thumbsup:
As said, 26" tubes work just fine. This is a Spec Turbo (lightweight) 26x2.00 tube
Kenda does make 27.5x2.10/2.35 tubes. Received some with the Nevegal samples they sent me. Do not know anywhere that stocks them.
Yup went straight to the source - after Kenda recommending going to the local LBS
and QB saying use 26" Kenda finally refer me to these guys.
so they make'em why will know one carry them ?? They all can get the tires !
Your tubes are here à http://www.beyondbikes.com/ItemMatr...utm_medium=GoogleProduct&utm_campaign=Froogle
i'm still trying to decipher your attempt at a sentence, but are you implying that the 29er was designed for men, and the 650b was designed for girls? or did i misinterpret what you wrote? please clarify...
jumped the gun on 650b tubes
:yikes: get this - tried ordering....they are on back order...doh.
what's up - all kinds of tires out there but can't get "correct" size tube :madman:
not giving up that easy, will keep you'all posted :eek:ut:
Just use a 26" tube... they are perfect for 650b and work flawlessly.
Cheers,
KP
this cracked me up...
I had the LBS order me some tubes, to carry on long rides just in case.
On the box its marked 650 when I took one out to put in my saddle pack I noticed on the tube its marked 26 X 1-1/2
PS I just returned from a multi day trip to Terlingua TX (Big Bend) all desert riding, every living plant has thorns NO FLATS go tubeless!
1 - 17 of 17 Posts
