1 - 17 of 17 Posts
what's the best shop I can get a 800lb 2"x7.875" spring for a fox vanilla-r ? Titanium really make much difference?
800 pounds are u crazy??
I got my spring from my LBS, it is a 750 lb. MRP manufactured by Eibach. A 800 lb spring isn't crazy for dudes that weigh over 200 pounds. Especially if you use the bike for everything. Sorry my spring on my FSR is a 850 lb. Here are a few pics, kinda crappy because my camera blows.
Samsonite Tester
Ti will drop a lot of weight over the steel version. Any lbs can order it from Fox direct.
Discussion Starter · #5 ·
no, im not crazy... Im also not a 105lb 14 year old scrawny kid. 800lbs was recomended by kona for my weight and bike. Call them crazy if you like.
yes but I want it cheapest. what am I looking to spend on a ti spring?. LBS lost their opportunity for sale by squandering convenience. Convenience out the window, price is all thats left for me. Anyplace online that sells em cheap?
Samsonite Tester
MTBsSd said:
psuh industries does em' for around $35 I think... Unless u want ti... then u'll be racking it out
Any lbs can order them from Fox for around $35 . Leave pussh out of the loop to save at least one shipping charge.
i have an 800 lb spring that i took off a brand new rc and havent used it. i thinnk its the same dimension but i have to check. you could buy it if you want.
Zonk0u said:
I do, let me know. the vanilla R is 2" stroke 7.875" eye2eye
the spring that i have is a fox spring- 800 lb x 2.30. the length of the spring is 6 inches so i think it should work. it is scartched up somewhat because i had some trouble getting it off the rc. so let me know if you want it..
Discussion Starter · #15 ·
I shot an email over to fox to check compatability, if all is good, how much?
Discussion Starter · #16 ·
he said it should work so long as it's not a DH spring. Something about using different sized retainers.
$ 20.00 + shipping. you can PM me with your adress if you want it so i can send it to you. We could use PayPal if you have it, but if you dont you could just send a check.
1 - 17 of 17 Posts
