Since Answer bought manufacturing rights from Progressive and seem to be manufacturing very similar designed shocks, I was wondering if they would be players in future servicing of the Progressive units. I understand that Hippie Tech services Progressive units.Bikinfoolferlife said:Friend of mine told me when discussing this the other day that Progressive has completely gotten away from the bicycle stuff and has made arrangments with Answer/Manitou for servicing....anyone verify this?
As far as one month ago, they still serviced shocks. I knwo because I was quoted 120 bucks for a service.bmadau said:Progressive isn't making any more bike (bicycle) stuff, but I think they are still servicing them. The policies change all the time, so a call is the only way to know for sure.
BM
I think it's as serviceable as any coil shock. If you have the means to fill it up with N2, and measure IFP depth and such, I think you can (in your case, I'm positive you can).MK_ said:Can 5th coil be user serviced?
I just got quoted $125 for a rebuild of the 5th on my SGS. So it looks like they are still doing the service in house.
_MK
I was told by Progressive that they would bring the shock up to the 06 standard. I'm not positive what it means other than they will replace some parts. Not sure what those are. I'm thinking seals had a run for their money in the 3 years of downhilling the shock was used for. So I'm inclined to just send it in. I figured if it was a documented procedure, I would give it a go. I don't like messing around with the IFP and ensuring there's no air trapped behind it. Thanks for the vote of confidence, though!Warp said:I think it's as serviceable as any coil shock. If you have the means to fill it up with N2, and measure IFP depth and such, I think you can (in your case, I'm positive you can).
But... may you find some busted seal or anything alike, you're on your own and sending the shock to Progressive as they don't sell the parts. If you happen to be friends with an authorized service center, I think they could order the parts for you.
Well... 125 bucks after three years is very fair rate! Worthy of sending it in. Mine lasted three months... little cost effective, I would say, so I'm not sending it in.MK_ said:I was told by Progressive that they would bring the shock up to the 06 standard. I'm not positive what it means other than they will replace some parts. Not sure what those are. I'm thinking seals had a run for their money in the 3 years of downhilling the shock was used for. So I'm inclined to just send it in. I figured if it was a documented procedure, I would give it a go. I don't like messing around with the IFP and ensuring there's no air trapped behind it. Thanks for the vote of confidence, though!
_MK
