Where can I get a turner post mount nut for DW 5 Spot?
659 Views 3 Replies 4 Participants Last post by  kreater
I have lost the little round nut that sits in the rear linkage and need a new one ASAP.
CRC are out of stock and both my local stockist don't have them. Anyone know a place that does have them in stock?
Thanks in advance!
1 - 4 of 4 Posts
Thanks in advance!
If you run out of options, just head down to your local Home Depot or hardware store, buy a steel or alum solid rod (bring your other one with you for sizing), get a drill bit/tap (M10 or M12?) & make your own, don't know any reason why it would not work?
Good luck.
Check with Dave at Redstone Cyclery (http://www.redstonecyclery.com/)
or direct with Turner.
_MK
greg at turner has always been super helpful with any of my hardware needs. give him a call, i have no doubt that he will sort you out. if you are in a hurry your local industrial supply stor might be able to help you out while you wait to get a proper replacement. Home depot or Brafasco where i am located.
1 - 4 of 4 Posts
