Buy-use at your own risk.... E263 Frame & Fork Adjuster - IceToolz|立富自行車有限公司|Lifu Bicycle Co., Ltd.
Need to break out the torch and add some heat in combination with the tool. That will fix it for sure.They're CLEARLY using it on an aluminum frame in the picture. What could possibly go wrong?
Yes if you soaked it over night in warm water.Will that work for carbon frames also?
You're all wrong, but you're the closest.It only works on bikes with disc brake tabs AND rim brake posts.
