You are kidding right? 5.1 has a 70 degree higher boiling point than any of the other grades. Except 5.0. If you are experiencing that that much heat in the brake system you have an issue anyway.AlexJK said:i bleed mine once a month because i'm a big guy running juicy 5s on a freeride hardtail, they get used a lot. once you get the process down, it's a trivial matter.
Get the avid bleed kit and toss out the DOT 5.1 (or sell it) and use Motul RBF-600, it's a DOT 4. It has a higher boiling point than Avid 5.1 and gives a firmer lever feel.
When the bleed syringes wear out (they will, fairly quickly too) go down to the farm supply store and pick up a similar syringe, they cost like a dollar a piece
Nope, i'm not kidding, the one thats even better than Motul RBF600 is Castrol SRF ($70 a liter)A from Il said:You are kidding right? 5.1 has a 70 degree higher boiling point than any of the other grades. Except 5.0. If you are experiencing that that much heat in the brake system you have an issue anyway.
BTW, it dosent matter the brand as much as the grade. Most of the brands all come from the same place anyway. The do change when you get into the "boutique" brands like Motul, Silkoline, Royal Purple and the such. But not very much.
The bottom line, dont try to re-engineer what you have and just maintain it and you will be fine. Remember two things.
1- the smartest people you will ever meet are on the web.
2- You will never know how hard you can push your equipment until you let someone else use it.
Your brakes fade and require bleeding every month? I'd return them. They're faulty.AlexJK said:i bleed mine once a month because i'm a big guy running juicy 5s on a freeride hardtail, they get used a lot. once you get the process down, it's a trivial matter.
Once a month is way beyond preventative maintenance. It is just unnecessary wear and tear.AlexJK said:they don't fade, but it's good preventative maintainance
Not getting how it is PM at all. The only time you should have to bleed, is if the system is opened.gmcttr said:Once a month is way beyond preventative maintenance. It is just unnecessary wear and tear.
Can I ask, what is it that you are preventing? While the system is closed everything should be just fine. One a year is plenty, most people don't do their car that often yet the risks are much higher.AlexJK said:i am obsessive, i need better brakes for the crap i ride, my juicys aren't enough... it keeps them running just fine. i've NEVER had an issue with them
Why even once a year, or ever(unless system has been open)siwilliams said:Can I ask, what is it that you are preventing? While the system is closed everything should be just fine. One a year is plenty, most people don't do their car that often yet the risks are much higher.
If you've never had an issue with them, why do you insist on opening them up and wasting fluid every month? Doing so does not make your brakes "better" or more powerful. It just makes them the most opened up brakes ever. Maybe you should try a larger rotor.AlexJK said:i am obsessive, i need better brakes for the crap i ride, my juicys aren't enough... it keeps them running just fine. i've NEVER had an issue with them
