Hi
I have a float forx 04. At the end of my seasson (one month ago), the right leg started leaking more oil than the normal coated oil film at the stanchion. It doesn`t leak trough the leg it just enough oil to get the seal covered with oil and dust.
Looking at a seals replacement on the way, I buyed enduro seals (great guy to make bussines, Chris) , but haven`t install them yet, because the last 5 rides the right leg stopped leaking oil. I don`t know if the problem was solved ( if there was any problem) or it`s just that the oil at the foam ring dryes out and no more oil can come outside.
I`ll do an oil change in next days and wanted to know if it is convenient to replace the seals or wait a little more to see if the stock fox are OK.
I`m consulting you with this decission, because I live in a country where buying things trough internet is possible but a little expensive, so I have to take the most durable life of these babys.
Thanks a lot!
bye
Thanks a lot!
bye
