So...
(all widths are internal)
I have crash replacement on a carbon wheel set. Application is XC race bike 100mm front and rear. Currently running 2.35 front (Ikon Exo) and 2.2 rear tires (XR2). So talked to wheel mfg and have the option on to get rear wheel fixed with either a 24mm or 30mm wheel. They don't make the 24mm any more only 30, but have some older stock of 24mm in bright colors. The 30mm wheel a few grams heavier, but does it makes sense to run 30mm wheel in the rear, and 24mm in front especially since I am running 2.2 in the rear? I can see going 30mm front and rear, but I am leaning toward 24mm rear just to match the front. I could easily to 2.4 in the rear and front, but again does it make sense to have rear rim wider?
So
Option 1
Front 24mm, rear 30mm
Option 2
Front 24mm, rear 24mm
So
Option 1
Option 2
