No, rip them. I ride carbon rims also and am 200#. Sound like nice wheels. I ride the Carbon for the stiffness and strength. The weight is a bonus!
YUP..climbing is the bestNo. The weight difference between ebike and normal bike is like 10-30lbs. There are riders out there that ride the same wheels on the same terrain and are 100lbs difference.
If anything just run a heavier casing tire. The weight and drag is far less important since ebikes generally climb really well. Because, you know, a motor…
Probably smart to get steel free hub body if it availableI am thinking of using a set of my wheels from another bike that is not an EMtb. They are carbon rims with I9 hubs. Does an EMtb need to have stronger / different wheels than a regular bike?
Thanks for any information.
...unless it's a SRAM/XD freehub or a Shimano Microspline. You'll be fine with alloy freehub bodies there. The issue is with Shimano HG style freehub bodies. The I9 freehub bodies in particular are very soft. There was a steel freehub body for the older I9 hubs but none are available for the Hydra hubs last time I asked them.Probably smart to get steel free hub body if it available
From the wheel's perspective, the ebike's increased weight is often within the margin of what the wheel will support. The only real issue is you may need to add a few psi in the tires to compensate.I am thinking of using a set of my wheels from another bike that is not an EMtb. They are carbon rims with I9 hubs. Does an EMtb need to have stronger / different wheels than a regular bike?
With Shimano HG cassettes, not very good for the alloy freehub body.From the wheel's perspective, the ebike's increased weight is often within the margin of what the wheel will support. The only real issue is you may need to add a few psi in the tires to compensate.
I am curious about the durability of i9 Hydra hubs specifically when it comes to eMTBs over the long term, with the assumption that the rider actually performs sensible maintenance on the hubs.
Not surprised, I've damaged Shimano freehub bodies with the cassette grooves which I know you're aware of.With Shimano HG cassettes, not very good for the alloy freehub body.
FWIW, there are no such issues with Shimano Microspline FH bodies. That said, I'm swapping all of my bikes over to SRAM over time. One holdout left. Soon will be standardized on SRAM drivetrain + Shimano brakes (maybe Maguras on one) for reliability and ease of service.Not surprised, I've damaged Shimano freehub bodies with the cassette grooves which I know you're aware of.
I don't hate Shimano but I've been using SRAM for the last few years simply for the benefits of the XD driver.
I had a strange experience with a customer with deep pockets who asked a lot of questions regarding eMTB's to include wheels and hubs asking for my opinion on what they should buy, but he was very persistent and insisted I tell him what I'd choose for reliability and durability. It was like he was looking to pay for stuff I would buy, but he would own and ride. Very strange.
In any case, I suggested a SRAM Eagle drive system with Onyx Vesper hubs. It's not so much about the Onyx being silent and instant engagement, I was simply looking at how the Onyx cams (instead of pawls) would have more surface area contact when engaged and may be more durable than something like a Hydra hub. He was clear about his intent on using something called a Towee tow strap, which is meant to tow/pull another rider/bike. I don't know at the time whether he intended on pulling a child, his wife or friends as some sort of trail shuttle. This was about 2 years ago.
He recently came in asking for use to do a full service as he was going away for a month for vacation so he left the bike at the shop. We took apart the Onyx Vesper hub and it looked really good on the inside. I found out he was towing friends so they'd have to wait less to get to the good stuff. It seems that things worked out well for him, but I wonder how traditional pawl type hubs would endure using it like he does, I simply don't know.
That's good to know. We've had bikes that came with the new XTR stuff but it wasn't in the shop for drive-related service so I have no experience with them.FWIW, there are no such issues with Shimano Microspline FH bodies. That said, I'm swapping all of my bikes over to SRAM over time. One holdout left. Soon will be standardized on SRAM drivetrain + Shimano brakes (maybe Maguras on one) for reliability and ease of service.
I can bleed Shimanos in my sleep, thus the brand loyalty. Maybe I just need a brand I don't need to bleed so often. ;-)That's good to know. We've had bikes that came with the new XTR stuff but it wasn't in the shop for drive-related service so I have no experience with them.
When it comes to brakes, some are outright rubbish IMHO, like the SRAM Guide R/RS. However after using Code RSC's for 2 years, I recently changed to the Hayes Dominion A4 and couldn't be happier. I know components are a preference thing with riders, but thought I'd share this. The D-A4 brakes are IMHO a much better designed Code RSC that's much easier to maintain, better thought out in terms of maintenance, easier to setup and the lever feel... I get asked about them constantly on the trails as they're not common here.
The MT7's are my favorite feeling brake, but I have Shimano Saints on my bike because I feel like they are the easiest to work on.I can bleed Shimanos in my sleep, thus the brand loyalty. Maybe I just need a brand I don't need to bleed so often. ;-)
I signed up as a Magura grassroots rider so I'll be trying out a set of the MT7's soon.
lol, I've blown a freehub and rear wheel doing this, but they took alot of abuse first. Surprisingly the drivetrains hold up well even on a middrive "moped", just don't shift under power.Unless you're talking about the insane amounts of power on some of those 50+ kilo jobs that are essentially electric motorcycles with pedals
Yup, there's no question that Shimano's are perhaps the easiest to bleed.I can bleed Shimanos in my sleep, thus the brand loyalty. Maybe I just need a brand I don't need to bleed so often. ;-)
