if it's disc you need 3x, no funky patterns need apply.
3 cross (or 4x for 36 spokes) is the most proven and reliable. It is not required for disc wheels though the more crosses the better.b12yan88 said:I am going to attempt to build my own wheels with Mav x517 ceramic, sun of bubba, and a cheap white industries boxxer rear(the 3 bolt disc kind ). I was looking at weird lacing patterns and i dont really know the difference. How do you guys like your wheels laced, and how to those boutique builders lace their wheels ?
Anyone that claims their magical weirdo lacing is superior to standard 3 cross if full of shhhheeeet. Not saying you can't do it or it won't hold up but it definitely won't be any better, stronger or faster.b12yan88 said:I am going to attempt to build my own wheels with Mav x517 ceramic, sun of bubba, and a cheap white industries boxxer rear(the 3 bolt disc kind ). I was looking at weird lacing patterns and i dont really know the difference. How do you guys like your wheels laced, and how to those boutique builders lace their wheels ?
Actually, if you try to build a disc wheel with radial lacing (zero cross) then you are in for a whole mess of trouble.shiggy©®™ said:3 cross (or 4x for 36 spokes) is the most proven and reliable. It is not required for disc wheels though the more crosses the better.
I never said you could use radial lacing with a disc wheel. You need (semi) tangental lacing for the wheel to work with hub brakes. Whether it is 2x, 3x, 4x or some combo depends on the number of spokes in the wheel and hub design among other factors. 24 spokes disc wheels tend to use 2x but the tangental spoke angle is about the same as a 32 spoke 3x wheel. A 36 spoke wheel can be laced 4x. A higher hub flange increases the tangental angle. Cane Creek and Spinergy build front disc wheels with radial right side spokes. I have built front wheels with 2x left / 3x right (32 spoke) and 3x left / 4x right (36 spoke) (reduces spoke tension difference slightly) and they work great. I have even built rear disc wheels 3x left / 1x right that are holding up fine (except for a hub shell failure that may or may not be related to the lacing).TobyNobody said:Actually, if you try to build a disc wheel with radial lacing (zero cross) then you are in for a whole mess of trouble.
Build it 3X and live happily ever after.
TN
I would (and do) build the rear wheel 3x drive / 2x non drive. These have been very reliable rim brake wheels. Usually do the front 1x or 2x just to be different.b12yan88 said:Sorry i should have clarifiied earlier. I am only buy this hub cause no one wants a 3 bolt disc pattern, cause there aren't any 3 bolt disc brakes. It was only 20 dollars marked down from some really expensive pricing. I am just using rim brakes and aren't even going to touch the disc mount. I might actually think about fiiling them right off. I was looking at this site
http://spokeanwheel.stormpages.com/lacingsr.htm
and the guy makes sense. I was thinking about for the rear wheel a hybrid crows foot on driive side, and a 2 cross on non drive side as he suggested. My front wheels wiill be traditional 3 cross.
