The LBS that you purchased the hubs and rims from can calculate the spoke length for you.
292 on both sides.playpunk said:I probably should have been more specific.
The Hope Pro II Singlespeed/Disc Hub is not on the Dt Swiss web site. The hope site doesn't have any tech info. I bought the hubs from universal Cycles, sono LBS.
I needanumber, in MM. DT SwissComps 3x,32 hole hubs/rims.
Thanks MC. I am looking for a massively overbuilt wheel, as I keep breaking the darn things.mikesee said:292 on both sides.
If you're looking for a massively overbuilt wheel, do it exactly as you've planned.
If you're less than ~200#, consider using SuperComps, or even Rev's if you're under ~160. The wide base of support on that dishless hub, combined with the stoutness of the Flow rim are why this works.
Cheers,
MC
