1 - 18 of 18 Posts
· Registered
I recently got a 2020 Levo Turbo Expert tricked out with a 170mm Fox 38, Magura MT5 eSTOP brakes, Cascade link, Planet 3, Thompson Elite stem, etc. It has the stock Butcher tires. I'm experimenting with a mullet plus wheelset...29x3.0 DHF front and 27.5x2.8 DHF rear, flipping the suspension into the high position. Just curious what folks are running on their Levos?
· This place needs an enema
Are your rims wide enough for those tires?
· E-Moderator
Tires are a personal thing and dependent on where you ride. I ride in So Cal and my choice of tires are from Maxxis F Assegai EXO + 29x2.6 and R Aggressor DD 27.5 x 2.5. I find ebikes goes thru rear tires fast and will pinch flat a tire in no time. I choose a rear tire with DD casing and I find the Aggressor grip good enough, but they last a lot longer then just about most tires out there.
· Registered
Discussion Starter · #14 ·
I'm in NorCal and where I live conditions are similar to the Socal riding I've done. Have you ever tried plus size tires on your ebike?
· E-Moderator
Maxxis DHR 27.5x2.8. I loved the tire, very expensive, but the biggest issue I had was keeping the side walls from pinching or rocks cutting them. I tried 4 2.8" tires and all had this issue.
1 - 18 of 18 Posts
