Do you have an ecc function on that fork, sounds like it's kicking in somehow...
It's got ETA, and the eta leg seems to be the source of notchiness. However it's notchy on both compression and rebound, but only when side-loaded...Bikinfoolferlife said:Do you have an ecc function on that fork, sounds like it's kicking in somehow...
tscheezy said:It does sound odd, but do an oil change with some good quality stuff soon. I sometimes change the oil once, ride the fork for an hour, and change it again. That way the fork gets really well rinsed inside with fresh oil before the final change. In my experience, it is the rebound leg which gets all gucked up. The ETA leg usually looks pretty fresh still.
MK_ said:I would guess that your bushings are wearing. You say it is flexier and it doesn't compress when side loaded. Do you have play in the fork when you hold the wheel between your legs and rock the bike sideways? Of with the brake on and rocking it back and forth?
_MK
I've messed around with tons of these forks. Air preloading one side is not going to cause notchiness in itself, esp. at only 5-7psi. There might be something else being effected by the air preload, though.FM said:The play I noticed was mainly standing besides the bike, pushing down on one grip only. It almost feels like one leg is OK and the other is notchy/loose.
Another thing that occurred to me: I have never ran air pre-load in this fork and it's always felt fine. recently I added 5-7psi to the non-ETA leg for a north-shore descent- and that was the same day I noticed the problem. Perhaps in imbalance in the spring stiffness (due to air pre-load) is behind this- it makes sense based on how the fork feels.
I'm going to change the oil and lose the air pre-load, hopefully that will set things straight.
