Hello everyone. My buddy and I both like to ride, but neither one of us have a whole lot of knowledge on bikes. He has a 2004 Gary Fisher Marlin, and I just picked up a 2006 Specialized Rockhopper comp disc.
We were both just wondering what the differences are. I mean, we can look at what type of brakes they have, or see that the shifters are different, but we don't know anything about the stuff. If any of you bike goo roos could help out that would be great.
Here are the specs:
2004 Gary Fisher Marlin:
Main frame Genesis Gold Series butted aluminum | Genesis Geometry
Fork Manitou Six | 80mm travel
Headset Aheadset | Semi-cartridge
Bottom bracket Shimano BB-LP28
Crank Bontrager Sport 42/32/22
Pedals Alloy platform
Front derailleur Shimano Alivio
Rear derailleur Shimano Deore
Shifters Shimano Alivio
Cassette SRAM 850 11-32, 8 speed
Chain IG-31
Front hub Alloy QR
Front rim Bontrager Maverick
Front spokes 14G stainless steel
Rear hub Shimano RM-40
Rear rim Bontrager Maverick OSB
Rear spokes 14G stainless steel
Front Tire IRC Mythos XC, 26x2.1
Rear tire IRC Mythos XC, 26x2.1
Front brake Alloy linear pull
Rear brake Alloy linear pull
Brake levers Alloy linear pull
Handlebar Bontrager Crowbar Sport
Stem Bontrager Sport
Grips Bontrager Ergo dual-density
Saddle Fisher ATB
Seatpost Bontrager Sport
2006 Specialized Rockhopper Comp Disc:
FRAME Specialized A1 Premium Aluminum, double-butted front triangle with ORE DT, 100mm travel, reinforced disc mount, externally machined HT, forged drop outs with eyelets and 06 replaceable derailleur hanger
REAR SHOCK None
HEADSET 1-1/8" threadless, sealed ball retainer
STEM Alloy A-head forged and tig weldeded w/ four bolt clamp
FORK RockShox Tora 318 SL, coil spring,100mm, 32mm Cr-Mo stanchions, alloy steerer, motion control damping, preloadand rebound adjustment w/ Lock Out
HANDLEBARS Alloy, 25mm XC rise, double-butted, 6 degree upsweep, 8 degree sweep, 640mm width
TAPE Specialized Enduro, dual density
BRAKE LEVERS Avid FR-5
REAR DERAILLEUR Shimano LX, long cage
CRANKSET Truvativ 5D w/alloy outer ring
CHAIN SRAM PC-951 w/ power link
CASSETTE SRAM PG-950, 9-speed, 11-34t
SHIFT LEVERS Shimano Deore SL, 9-speed
FRONT DERAILLEUR Shimano Deore, 34.9mm clamp, top swing, bottom pull
REAR BRAKE Avid BB-5, mechanical disc with 6" Roundagon rotor
FRONT BRAKE Avid BB-5, mechanical disc with 6" Roundagon rotor
CHAINRINGS 22t/32t heat treated Cro-Mo/44t 7075 aluminum
TUBES Specialized 26x2.0 schraeder valve
REAR TIRE Specialized Resolution Pro, 26x2.0", aramid bead
FRONT TIRE Specialized Resolution Pro, 26x2.0", aramid bead
SPOKES 1.8mm, stainless w/brass nipples
REAR HUB Shimano 475, 32h w/ Shimano QR
FRONT HUB Specialized disc, 32h double sealed w/alloy QR
BOTTOM BRACKET Truvativ, Power Spline, sealed cartridge bearing with alloy cups
RIMS SUN DS2 disc, double wall, 32h w/eyelets
PEDALS Alloy 1pc body and cage
SADDLE Specialized BGSport MTB, light weight foam
SEAT POST Alloy 30.9mmx350mm, micro adjust
SEAT BINDER Alloy collar with Q/R
NOTES Chain stay protector, reflectors, clear coat, owners manual
Here are the specs:
Chain IG-31
Front hub Alloy QR
Saddle Fisher ATB
REAR SHOCK None
