1 - 16 of 16 Posts
· West Chester, PA
Discussion Starter · #3 ·
Yes, I know the issues at hand. Thats why I'm asking here before I use something from home depot that melts the whole fork. There are several guys on here who have stripped entire scott frames. I'd like to know what THEY used.
· bike rider
Good Old sandpaper and LOTS of patience and elbow grease. After I get bored with my A9c I'm going to sand down my frame and fork just to be different but since this is the WW forum I'm also doing it to lose some weight. ;)
· West Chester, PA
Discussion Starter · #6 ·
stefano_cercone said:
Carbolift
Interesting. I also read on a car forum that any stripper safe for fiberglass will also be safe on carbon composites. The downside is that the stuff is very mild and usually takes forever to work. This stuff may be a re-packaged marine stripper.
What I'm doing is this. I bought a carbon road frame on ebay. I'm using the fork from my present frame but it is painted white. I just want to make it bare carbon. I'll sand it if I have to.
· Go faster!
I believe they are right at the car forum. I've used paint stripper on car parts and it acts much faster than carbolift. You could do a test with some old carbon part and car paint stripper and see if it damages the carbon fibre.
· Registered
Careful with color strippers! If they are meant to be used on steel or Al parts, they might interact with the resin and eat it as well.
But there's a thread in the tooltime forum and Carbolift seems to be the right way to go.
· Registered
Just use sand paper. I have stripped several carbon parts. Test the part with some 800-1000 grit paper. That should be enough to remove...if not, step down do 600. Once you are done with the 800-600 grit, move up to 1000-1500 grit to remove the fine scratches.
It's not hard to do and much safer than using chemicals.
· FIRENZE rulez !!
1 - 16 of 16 Posts
