I laced up a WTB LaserDisc Lite Rear hub to a Mavic Open Pro rim using DT Swiss Revolution spokes double butted 15/17 guage. I started with even tension about 50 Kgf. Trued the wheel laterally and radially. Then I started adding tension, by a quarter turn at a time. After each go round, the wheel was substantially out of true, and it added less than 5 Kgf, but tension was still even, so I retrued. did this a couple times. I guess because of the thin spokes, each round of tensioning was adding hardly any tension (I measured with a tensiometer). I then tightened each nipple a full turn. although tension still was not even up to 100 Kgf, the rim became waaaaay out of true, such that I'm not even sure I'll be able to true it, much less keep even tension.:madman: Did I just use too thin of spokes? Never had this problem before with 14/15 guage spokes. Special trick to using thinner spokes?
