Destroy said:
I've never ridden a mtn bike more expensive that mine, $1500 Trek Liquid 10. Rather humbling, I know. <snif>
Assuming similar purpose bikes right off the show room floor, what are some obvious things when riding that the average rider would definitely notice between a $1500 bike and a $5000+ mtn bike?
I'm just imagining a major difference but I dunno. I keep thinking like how a Toyoto MR2 vs a Ferrari Testarossa (sp?).
Ok, I'll chime in....
Some manufacturers have a line of bikes that span from sub $2k to $5k and use the exact same frame. Cannondale Rush comes to mind. Given that the differences are going to be the components.
Here is what you get with a $1500 bike:
Good frame
Lower end fork and possible lower end shock
Lower end shifters and drive train
Lower end wheels, hubs, tires
Lower end brakes and levers
Lower end, heavier components
Savings of $3500 to use toward a nice vacation and a few upgrades.
Here is what you get on the same frame of a $5000 bike:
Good frame
Top end fork and possible shock as well (some are the same shock across the board)
Top end shifters and drive train (shifts better, holds up better, much lighter)
Top end wheels, hubs, tires (lighter, stiffer, stronger)
Top end Brakes and levers (better modulation, lighter, more adjustable)
Top end lighter, stronger components (seatpost, stem, handlebars, saddle, headset, etc)
A $5000 bike with a lot of bling that makes people woo with envy.. Sorry, no vacation and not much need for upgrades....
If you are talking about your average $1500 bike against some other $5000 with different frames or manufacturers, I don't even know how to start comparing. There can be a vast sea of differences from what the frame is made of to stiffness, lightness, and everything in between.
If you have to ask the differences, chances are you don't need a $5000 bike. Get one that reflects the kind of riding you intend or want to do and go for it. Get a lower end bike that uses the same frame on the top end bikes. Ie.. I got a Yeti 575 with the Enduro package which has the same frame as the 575 with the Pro package. The only difference is the components. Those can be upgraded.
