What would cause this? chain slack
1021 Views 8 Replies 5 Participants Last post by  mtnbkr33
During the middle of my ride on saturday my chain came off the top or my cassette. I was able to get the chain back on but once i stopped peddaling the top of my chain would become slack. I took my cassette off and made sure everything was ok there and it seems fine. I checked the rear der and everything looks good there. I have no idea what went wrong and i can not ride it like this. Any suggestions?
1 - 9 of 9 Posts
this is what it looks like, the red is when i am not pedaling. any guesses?
This is just a quick guess. It might be your rear hub. The freewheel is not disengaging when you are coasting. Rebuild your freewheel, if you can.
could be that, but it's also possible that your rear hub's cassette freebody is encountering some major drag. Knowing the hub make could help us identify the issue.
later, Chad
Chad
Its the pro hope II that i got from you in November. The above picture is not the actual bike picture just one that i found. here is a picture of my hub
Couple Other Ideas
Stiff chain link/links...this could cause the chain to get hung up in the r derailleur, on a cassette cog or on a chainring.
Bent/damaged/worn chainring teeth...this would hold the chain on the chainring longer and cause it to wrap down the back closer to the chainstay when not under load.
If the chain came off the top of the cassette I would imagine it got caught between the cassette and spokes and that could have damaged it a bit causing stiff links.
Clean/degrease your chain then lube it. if that doesn't help, check if your freewheel is spinning freeley. If, not, take it to your LBS or pull it apart and grease it.
If all else fails, your chainring or cassete gears might be worn.
Joe...... after you've checked the links and chain like both Shane and Eli have outlined also check behind the cassette to make sure the spokes were not mangled and making contact with the cassette which could also cause the drag...something is making contact and i'd take the cassette off of the wheel to inspect (chain, cassette, chain).
good luck !
I took my bike into the lbs and they can see that a seal has came loose and is misaligned. they are going to take my hub apart and fix this. i hope this is the problem but i do not know what would have caused this.
1 - 9 of 9 Posts
