if you want it to feel stiffer(wrong analogy but sounds right) use a slightly heavier weight oil.Pentacle said:wow, that was fast! thanks, much appreciated!
thats probably unessessary with the damper adjustments on that fork.snowskilz said:if you want it to feel stiffer(wrong analogy but sounds right) use a slightly heavier weight oil.
If ya want it smoother use a lighter weight oil
