1 - 17 of 17 Posts
· Registered
Even Specialized still lists 700c tubes as road tubes. Is it still better to stretch a 26" tube, as per 29er reference guide?
(I don't see any road tubes listed by Specialized as 51mm, isn't that what a 2" tire requires?)
· rider
I like using real 29er tubes. Kenda, Bontrager & WTB just to name a few, are all selling 29er tubes. Bonti has an ultralight 29er tube that seemed like a good idea (came on my bike) but were very leak prone. Now I just run the standard weight tubes. Not picky about brands.
Of course the simple answer is "the one that holds air"!
29erchico
· Joenes
No tube
I was so happy with Stan's on my 26" wheels, when I sold that bike I swapped the kit for tubes and kept the Stan's for my new bike.
When I got my GF Rig, before riding it, I removed the inner tubes and installed my old (26") stan's rim strips, added the goo...viola.
Just as I experienced on the old bike, not a single problem as of yet.
· Registered
Discussion Starter · #9 ·
burner said:
Pacman, I also use 26" Specialized Turbo Tubes in my 29er, they've worked great for me in SoCal. I see you on the SoCal boards, but now you went 29er? What'd ya get? We may need to get a 29er tour de santa monicas going.
I'm watching a clock go tick - tick - tick. In January(?) I'll have a S.I.R. Niner. Then, let the touring start.
· Cold. Blue. Steel.
Wish I Were Riding said:
I ordered some 26" Turbo tubes from Specialized when I ordered my tires. This was based on Padre's recomendations in the past. I hope they will work.
Ditto that. I took Padre's advice over the summer when I was one of the lucky 20 to receive the proto version of the tires. I raced mine like crazy on a rigid SS and only flatted once- when going balls out at the SSWC on the rockiest, gnarliest course I have ever seen!
I will continue to ride these tubes. Just "pre-stretch" them by airing them up to about 150% of their actual size before inserting them in the tire. I leave them overnight and, voila!, they are 29er tubes, hahaha!
OGG
· Joenes
In my experience tubes vs. tubeless (35 yrs. tubes/ 2yrs. tubeless), tubes are nowhere near as reliable as tubeless. Many, many flat tires from punctures and pinches. Zero punctures or pinches with tubeless and I have only used Stan's with a traditional tire not UST.
I would agree that tubes are more easily reparable but not more reliable.
The ride quality between the two isn't a fair comparison, like comparing clips and straps to clipless pedals or friction shifting to index shifting. Tubeless gives a much more comfortable ride and traction that can't be matched by tubed tires unless you want a guaranteed pinch.
· Premium Member
Tubes vs DIY tubeless has been discussed and debated here and on other forums to exhaustion. I will not get into another now.
The cons of DIY far outweigh the pros for me.
· giddy up!
I take it your experience has been with 26" bikes and not 29"ers.
B
1 - 17 of 17 Posts
