1 - 14 of 14 Posts
· Registered
specialized crosstrail 2016 hybrid, specialized allez road
Evening all,
can anybody help me identity this bottom bracket and more importantly the correct tool to remove it. Look at enclosed attachment, a standard 20spline bb remover will not do it note the spacing on enclosed attachment the profile is a mixture of narrow and wide spacing and any tool would need splines on the inner circumference of the tool to mate correctly with the one on my bike.
bike is a 2016 specialized crosstrail and I cannot find any info on the web to help,
Thanks John
Eye Automotive tire Fluid Liquid Water
· transmitter~receiver
A hammer?
I find it very hard to believe that Specialized put a square taper BB with a proprietary interface on a bike in 2016. Is it original?
Then again, I could just be out of touch.
It doesn’t look like a tool interface, which is why I suggest smacking it on the end of the axle with a hammer.
· Registered
· Registered
Discussion Starter · #5 ·
A hammer?
It is original I've had bike from new, bit of a bad buy what with tektro brakes, wish I'd spent a lot more but didn't know how much I'd enjoy cycling suffice to say I've brought more bikes since.
Really don't wanna use a hammer
· Registered
Discussion Starter · #6 ·
Just about to say the same thing.
Here is Park Tools guide on bottom bracket tools.
Thanks Mike for the park-tool link, sadly can't see the variant I need my bb has external notches so any splined tool would have to have the splines on the inner circumference of the tool not the outer, as they wouldn't mate together, a real puzzle, not impressed with specialized designed!
· Registered
Hard to tell with the straight on shot. Are you saying the area with the red line is higher than the area with the blue line?
Automotive tire Liquid Fluid Water Rim
· Registered
You have the answer twice above...
The standard 20-tooth tool will work.
Automotive tire Fluid Auto part Automotive wheel system Circle
· Registered
Discussion Starter · #9 ·
Thanks Mike , the blue is higher than the red,I've confused the issue and myself by keep looking at photo not item in situ, apologies tool and bb now on order will let you know how I get on , thanks
Interested to see if the 20t works. I don’t understand how the tool can “skip” teeth, since the missing notches would prevent the rest of the tool from engaging. Maybe I’m not thinking about it correctly.
· Disgruntled Peccary
Those spots where metal is missing would not actually prevent the tool from engaging, as there's simply no metal there.
· Registered
Discussion Starter · #14 ·
Evening all,
Thanks John View attachment 1959245
cheers Mike and others who ansewered the question, all fixed and rolling again
1 - 14 of 14 Posts
